Tina
第2楼2007/09/17
我试着翻译一下,不一定准确,就当是起一个抛砖引玉的作用吧(欢迎大家多多拍砖)
Method: Comparison method
Principle: For the same series, the same quantity of viscosity and torque could be measured with the same temprature and spindle. By comparing with the value of RVMASTER measured, the instrument which is under calibration could be judged whether it is accurate or not.
Specification: The difference should be not more than 1.0 of the measured value of RVMASTER and of the instrument being calibrated.
何当奇
第4楼2007/09/18
校准方法:比较法
校准原理: 在同样测量温度和使用同样转子, 转速, 对于同一系列, 可测量出同样的黏度值和扭矩读数. 通过与RVMASTER标准机读数几表, 可判断出被校准仪器是否准确. 标准: RVMASTER标准机读数与被校准仪器读数相差不得大于1.0
[/quote]
Specification: The difference should be not more than 1.0 of the measured value of RVMASTER and of the instrument being calibrated.[/quote]
建议
相同转速没有翻译出来。
under the same temperature 吧?
The accuracy of the instrument which is under calibration could be judged.
cuggi
第5楼2007/09/18
站在前人肩膀上...
Principle:For the same series,the same viscosity-value and torque-reading can be measured in the same temperature with same rotor and speed. Through comparing with the value of RVMASTER standard machine,it could be judged whether the instrument is accurate or not.
Specification: The difference should be not more than 1.0 of the measured value between RVMASTER and the instrument being calibrated.
立静致远
第8楼2007/09/18
最终版(个人意见)
Method : Comparison method
Principle: For the same series , the same viscosity value and torque could be measured under the same test temperature, the same spindle, and the same speed. By comparing with the value of RVMASTER displayed, the accuracy of the instrument which is under calibration could be judged.
Specification: The Tolerance between RVMASTER and calibrating instrument is no more than 1.0
