Liquid water formation and flooding in PEM fuel cell gas distribution channels can significantly degrade fuel cell performance by causing substantial pressure drop in the channels and by inhibiting the transport of reactants to the reaction sites at the catalyst layer. A better understanding of the mechanisms of discrete water droplet transport by air flow in such small channels may be developed through the application of quantitative flow visualization techniques. This improved knowledge could contribute to improved gas channel design and higher fuel cell efficiencies. An experimental investigation was undertaken to gain better understanding of the relationships between air velocity in the channel, secondary rotational flows inside a droplet, droplet deformation, and threshold shear, drag, and pressure forces required for droplet removal. Micro-digital-particle-image-velocimetry (micro-DPIV) techniques were used to provide quantitative visualizations of the flow inside the liquid phase for the case of air flow around a droplet adhered to the wall of a 1 mm x 3 mm rectangular gas channel model.
方案
燃料电池中速度场检测方案(粒子图像测速)
