〓疯子哥〓
第1楼2007/09/30
0.1g 托盘pan 指针刻度表pointer and scale
crossbeams and sliding weights 游码
分析天平 two-pan/single-pan analytical balance
滴定管 burette glass bead(basic) nozzle
移液管 pipette 胖肚 elongated glass bulb
洗耳球 rubber suction bulb
玻棒 glass rod
玻璃活塞 stopcock
容量瓶 pyknowmeter flasks
比重瓶 (one-mark)volumetric flasks
胖肚吸管 one-mark pipette
刻度吸管 graduated pipettes
锥形瓶(conical flask) 250ml×4 药匙(medicine spoon)×1
(Erlenmeyer flask) 100 ml×3 滴管(drip tube;dropper)×2
烧杯(beaker) 500 ml×1 玻棒(Glass stic)×2
250 ml×3 木试管夹(test tube clamp;test tube holder)×1
100 ml×3 胖肚吸管(straws) 25 ml×1
50 ml×2 10 ml×1
容量瓶(volumetric flask) 100 ml×2 乳钵(morta)×1
50 ml×4 洗耳球(ear washing bulb)
碘量瓶 (Iodine numoe flask; iodine flask) 500 ml×3
试剂瓶 (reagent bottle) (无色)×2
(棕色)×2 配洗液:
量筒(cylinder) 100 ml×1 K2Cr2O72g+5ml水→65mlH2SO4
(graduated cylinder)10ml×1 边加边搅拌(stir)。
铁支架(siderocradle)+蝴蝶架
白瓷板(White Porcelain Board ) (一)清点仪器(to count;to make an inventory)
酸式滴定管(Acid burette) 25 ml×1 配洗液 (Lotion)
碱式滴定管(Alkali burette)25 ml×1 一般仪器的洗涤
直型冷凝器(rectocondensor)×1 容量瓶(volumetric flask)
漏斗架 (funnel stand) ×2 移液管(pipe)
水浴锅(water bath kettle) ×1
温度计(Thermometer;hygrometer;hydroscope) ×1
电炉(electric furnace;electric hot plate;electric stove) 四人一个
分析化学:analytical chemistry
定性分析:qualitative analysis
定量分析:quantitative analysis
物理分析:physical analysis
物理化学分析:physico-chemical analysis
仪器分析法:instrumental analysis
流动注射分析法:flow injection analysis;FIA
顺序注射分析法:sequentical injection analysis;SIA
化学计量学:chemometrics
绝对误差:absolute error
相对误差:relative error
系统误差:systematic error
可定误差:determinate error
随机误差:accidental error
不可定误差:indeterminate error
准确度:accuracy
精确度:precision
偏差:debiation,d
平均偏差:average debiation
相对平均偏差:relative average debiation
标准偏差(标准差):standerd deviation;S
相对平均偏差:relatibe standard deviation;RSD
变异系数:coefficient of variation
误差传递:propagation of error
有效数字:significant figure
置信水平:confidence level
显著性水平:level of significance
合并标准偏差(组合标准差):pooled standard debiation
舍弃商:rejection quotient ;Q
滴定分析法:titrametric analysis
滴定:titration
容量分析法:volumetric analysis
化学计量点:stoichiometric point
等当点:equivalent point
电荷平衡:charge balance
电荷平衡式:charge balance equation
质量平衡:mass balance
物料平衡:material balance
质量平衡式:mass balance equation
酸碱滴定法:acid-base titrations
质子自递反应:autoprotolysis reaction
质子自递常数:autoprotolysis constant
质子条件式:proton balance equation
酸碱指示剂:acid-base indicator
指示剂常数:indicator constant
变色范围:colour change interval
混合指示剂:mixed indicator
双指示剂滴定法:double indicator titration
非水滴定法:nonaqueous titrations
质子溶剂:protonic solvent
酸性溶剂:acid solvent
碱性溶剂:basic solvent
两性溶剂:amphototeric solvent
无质子溶剂:aprotic solvent
均化效应:differentiating effect
区分性溶剂:differentiating solvent
离子化:ionization
离解:dissociation
结晶紫:crystal violet
萘酚苯甲醇: α-naphthalphenol benzyl alcohol
奎哪啶红:quinadinered
百里酚蓝:thymol blue
偶氮紫:azo violet
溴酚蓝:bromophenol blue
配位滴定法:compleximetry
乙二胺四乙酸:ethylenediamine tetraacetic acid,EDTA
螯合物:chelate compound
金属指示剂:metal lochrome indcator
氧化还原滴定法:oxidation-reduction titration
碘量法:iodimetry
溴量法:bromimetry ]
溴量法:bromine method
铈量法:cerimetry
高锰酸钾法:potassium permanganate method
条件电位:conditional potential
〓疯子哥〓
第2楼2007/09/30
abatement 1:减少 2:消除;
ablution 1:清洗 2:洗净液;
abnormal distribution 1:非正态分布;
above-critical 临界以上的;
above proof 超过标准;
abrasive 1:磨料,研磨机;
abrupt change !:陡变 2:(滴定)突跃;
absolute calibration curve method 绝对校准曲线法;
absolution configuration 绝对构型;
absolute deviation 绝对偏差;
absolute error 绝对误差;
absolute ethyl alcohol 无水乙醇;
absolute humidity 绝对湿度;
absolute manometer 绝对压力计;
absolute isotopic abundance measurement 绝对同位素丰度测量;
absolute precision 绝对精密度;
absolute sensitivity 绝对灵敏度;
absolute mobility 绝对淌度;
absolute retention time 绝对保留时间;
absolute refractive index 绝对折射率;
absolute stability constant 绝对稳定常数;
absolute temperature 绝对温度;
absorbance index =absorptivity 1:吸收系数 2:吸光系数;
absorbance 吸收度,吸光度;
absorbance ratio 吸光度比值;
absorbed dose 吸收计量;
absorbed layer (被)吸收层;
absorbent 吸收剂;吸收的,有吸收力的;
absorbing band 吸收带;
absorption 吸收;
absorption chamber 吸收室;
absorption factor 吸收率;
absorption index 吸收指数;
absorption peak 吸收峰;
absorption power 吸收能力;
absorption region 吸收范围;
absorption spectroscopy 吸收光谱法;
absorption spectrum 吸收光谱;
absorption tube support 吸收管架;
absorption value 吸收值;
abundance 丰度;
abundance of element 元素丰度;
accelerator (粒子)加速器;
acceptable life 有效使用寿命;
acceptance quality level (AQL)合格质量标准;
acceptance level 验收标准;
accidental error 偶然误差;
accessory substance 副产物;
accommodation 调节;
accuracy 准确度;
acetaldehyde 乙醛;
acetic acid 乙酸;
acetic anhydride 乙酸酐;
acetoacetic ester 乙酰乙酸酯;
acetone 丙酮;
acetone titration 丙酮滴定法;
acetylation 乙酰化;
acetylene 乙炔;
acetyl group 乙酰基;
acetylenic bond 炔键;三键;
achiral molecule 非手性分子;
acidate 酸化,酰化;
acid-base equilibrium 算见平衡,
acid degree 酸度;
acid dissociation constant 酸离解常数;
acidic 酸式,酸性的;
acidic solvent 酸性溶剂;
acidity 酸度;
acidometer=acidimeter 酸度计;
acticarbon 活性炭;
activate 活化,激活,使…产生放射性;
activated state 活化态;
activating 活化;
activating agent 活化剂;
activator 激活剂;
active center 活性中心;
active group 活性基团;
active mass 有效质量;
active site 活性点;
actual column plate 实际塔板数;
adapter tube 接管;
additional peak 附加峰;
additivity 加和性;
adjacent 相邻的,邻位的
〓疯子哥〓
第3楼2007/09/30
匀浆填充 slurry packing
停流进样 stop-flow injection
阀进样 valve injection
柱上富集 on-column enrichment
流出液 eluate
柱上检测 on-column detection
柱寿命 column life
柱流失 column bleeding
显谱 visualization
活化 activation
反冲 back flushing
脱气 degassing
沟流 channeling
过载 overloading
洗脱序列 eluotropic series
洗脱(淋洗) elution
等度洗脱 gradient elution
梯度洗脱 gradient elution
(再)循环洗脱 recycling elution
线性溶剂强度洗脱 linear solvent strength gradient
程序溶剂 programmed solvent
程序压力 programmed pressure
程序流速 programmed flow
展开 development
上行展开 ascending development
下行展开 descending development
双向展开 two dimensional development
环形展开 circular development
离心展开 centrifugal development
向心展开 centripetal development
径向展开 radial development
多次展开 multiple development
分步展开 stepwise development
连续展开 continuous development
梯度展开 gradient development
〓疯子哥〓
第4楼2007/09/30
磁旋比:magnetogyric ratio
磁量子数:magnetic quantum number,m
进动:precession
弛豫历程:relaxation mechanism
局部抗磁屏蔽:local diamagnetic shielding
屏蔽常数:shielding constant
化学位移:chemical shift
国际纯粹与应用化学协会:IUPAC
磁各向异性:magnetic anisotropy
远程屏蔽效应:long range shielding effect
结面:nodal plane
自旋-自旋偶合:spin-spin coupling
自旋-自旋分裂:spin=spin splitting
单峰:singlet,s
双峰:doublet,d
三重峰:triplet,t
四重峰:quartet
五重峰:quintet
六重峰:***tet
偕偶:geminal coupling
邻偶:vicinal coupling
远程偶合:long range coupling
磁等价:magnetic eqivalence
自旋系统:spin system
一级光谱:first order spectrum
二级光谱(二级图谱):second order spectrum
C-H光谱:C-H correlated spectroscopy,C-H COSY
质谱分析法:mass spectrometry
质谱:mass spectrum,MS
棒图:bar graph
选择离子检测:selected ion monitoring ,SIM
直接进样:direct probe inlet ,DPI
接口:interface
气相色谱-质谱联用:gas chromatography-mass spectrometry,GC-MS
高效液相色谱-质谱联用:high performance liquid chromatography-mass spectrometry,HPLC-MS
电子轰击离子源:electron impact source,EI
离子峰:quasi-molecular ions
化学离子源:chemical ionization source,CI
场电离:field ionization,FI
场解析:field desorptiion,FD
快速原子轰击离子源:fast stom bombardment ,FAB
质量分析器:mass analyzer
磁质谱仪:magnetic-sector mass spectrometer
四极杆质谱仪(四极质谱仪):quadrupole mass spectrometer
原子质量单位:amu
离子丰度:ion abundance
相对丰度(相对强度):relative avundance
基峰:base peak
质量范围:mass range
分辨率:resolution
灵敏度:sensitivity
信噪比:S/N
分子离子:molecular ion
碎片离子:fragment ion
同位素离子:isotopic ion
亚稳离子:metastable ion
亚稳峰:metastable peak
母离子:paren ion
子离子:daughter
含奇数个电子的离子:odd electron
含偶数个电子的离子:even eletron,EE
均裂:homolytic cleavage
异裂(非均裂):heterolytic cleavage
半均裂:hemi-homolysis cleavage
重排:rearragement
分子量:MW
α-裂解:α-cleavage
固定相:stationary phase
化学键合相:chemically bonde phase
封尾、封顶、遮盖:end capping
手性固定相:chiral stationary phase,CSP
恒组成溶剂洗脱:isocraic elution
梯度洗脱:gradient elution
紫外检测器:ultraviolet detector,UVD
荧光检测器:fluorophotomeric detector,FD
电化学检测器:ECD
示差折光检测器:RID
光电二极管检测器:photodiode array detector ,DAD
三维光谱-波谱图:3D-spectrochromatogram
蒸发光散射检测器:evaporative light scattering detector,ELSD
释药系统(drug delivery system,DDS)
中国药典(Chinese Pharmacopoeia,ChP)
美国药典(The United States Pharmacopoeia,USP)
美国国家处方集(The National Formulary,NF)
英国药典(British Pharmacopoeia,BP)
欧洲药典(European Pharmacopoeia,Ph.Eup)
国际药典(The International Pharmacopoeia,Ph.Int)
良好药品实验研究规范(Good Laboratory Practice,GLP)
良好药品生产规范(Good Manufacture Practice,GMP)
良好药品供应规范(Good Supply Practice,GSP)
良好药品临床试验规范(Good Clinical Practice,GCP)
分析质量管理(Analytical Quality Control,AQC)
边缘效应 edge effect
斑点定位法 localization of spot
放射自显影法 autoradiography
原位定量 in situ quantitation
生物自显影法 bioautography
归一法 normalization method
内标法 internal standard method
外标法 external standard method
叠加法 addition method
普适校准(曲线、函数) calibration function or curve [function]
谱带扩展(加宽) band broadening
(分离作用的)校准函数或校准曲线 universal calibration function or curve [of separation]
加宽校正 broadening correction
加宽校正因子 broadening correction factor
溶剂强度参数 ε0,so
〓疯子哥〓
第5楼2007/09/30
生色团:chromophore
助色团:auxochrome
红移:red shift
长移:bathochromic shift
短移:hypsochromic shift
蓝(紫)移:blue shift
增色效应(浓色效应):hyperchromic effect
减色效应(淡色效应):hypochromic effect
强带:strong band
弱带:weak band
吸收带:absorption band
透光率:transmitance,T
吸光度:absorbance
谱带宽度:band width
杂散光:stray light
噪声:noise
暗噪声:dark noise
散粒噪声:signal shot noise
闪耀光栅:blazed grating
全息光栅:holographic graaing
光二极管阵列检测器:photodiode array detector
偏最小二乘法:partial least squares method ,PLS
褶合光谱法:convolution spectrometry
褶合变换:convolution transform,CT
离散小波变换:wavelet transform,WT
多尺度细化分析:multiscale analysis
供电子取代基:electron donating group
吸电子取代基:electron with-drawing group
荧光:fluorescence
荧光分析法:fluorometry
X-射线荧光分析法:X-ray fulorometry
原子荧光分析法:atomic fluorometry
分子荧光分析法:molecular fluorometry
振动弛豫:vibrational relexation
内转换:internal conversion
外转换:external conversion
体系间跨越:intersystem crossing
激发光谱:excitation spectrum
荧光光谱:fluorescence spectrum
斯托克斯位移:Stokes shift
荧光寿命:fluorescence life time
荧光效率:fluorescence efficiency
荧光量子产率:fluorescence quantum yield
荧光熄灭法:fluorescence quemching method
散射光:scattering light
瑞利光:Reyleith scanttering light
拉曼光:Raman scattering light
红外线:infrared ray,IR
中红外吸收光谱:mid-infrared absorption spectrum,Mid-IR
远红外光谱:Far-IR
微波谱:microwave spectrum,MV
红外吸收光谱法:infrared spectroscopy
红外分光光度法:infrared spectrophotometry
振动形式:mode of vibration
伸缩振动:stretching vibration
对称伸缩振动:symmetrical stretching vibration
不对称伸缩振动:asymmetrical stretching vibration
弯曲振动:bending vibration
变形振动:formation vibration
面内弯曲振动:in-plane bending vibration,β
剪式振动:scissoring vibration,δ
面内摇摆振动:rocking vibration,ρ
核磁共振:nuclear magnetic resonance,NMR
核磁共振波谱:NMR spectrum
核磁共振波谱法:NMR spectroscopy
扫场:swept field
扫频:seept frequency
连续波核磁共振:continuous wave NMR,CW NMR
Fourier变换NMR:PFT-NMR,FT-NMR
二维核磁共振谱:2D-NMR
质子核磁共振谱:proton magnetic resonance spectrum,PMR
氢谱:1H-NMR
碳-13核磁共振谱:13C-NMR spectrum,13CNMR
自旋角动量:spin angular momentum
非晶体电极:non- crystalline electrodes
刚性基质电极:rigid matrix electrode
流流体载动电极:electrode with a mobile carrier
气敏电极:gas sensing electrodes
酶电极:enzyme electrodes
金属氧化物半导体场效应晶体管:MOSFET
离子选择场效应管:ISFET
总离子强度调节缓冲剂:total ion strength adjustment buffer,TISAB
永停滴定法:dead-stop titration
双电流滴定法(双安培滴定法):double amperometric titration
普朗克常数:Plank constant
电磁波谱:electromagnetic spectrum
光谱:spectrum
光谱分析法:spectroscopic analysis
原子发射光谱法:atomic emission spectroscopy
质量谱:mass spectrum
质谱法:mass spectroscopy,MS
紫外-可见分光光度法:ultraviolet and visible spectrophotometry;UV-vis
肩峰:shoulder peak
末端吸收:end absorbtion
〓疯子哥〓
第6楼2007/09/30
溴酸钾法:potassium bromate method
硫酸铈法:cerium sulphate method
偏高碘酸:metaperiodic acid
高碘酸盐:periodate
亚硝酸钠法:sodium nitrite method
重氮化反应:diazotization reaction
重氮化滴定法:diazotization titration
亚硝基化反应:nitrozation reaction
亚硝基化滴定法:nitrozation titration
外指示剂:external indicator
外指示剂:outside indicator
重铬酸钾法:potassium dichromate method
沉淀滴定法:precipitation titration
容量滴定法:volumetric precipitation method
银量法:argentometric method
重量分析法:gravimetric analysis
挥发法:volatilization method
引湿水(湿存水):water of hydroscopicity
包埋(藏)水:occluded water
吸入水:water of imbibition
结晶水:water of crystallization
组成水:water of composition
液-液萃取法:liquid-liquid extration
溶剂萃取法:solvent extration
反萃取:counter extraction
分配系数:partition coefficient
分配比:distribution ratio
离子对(离子缔合物):ion pair
沉淀形式:precipitation forms
称量形式:weighing forms
物理化学分析:physicochemical analysis
仪器分析:instrumental analysis
电化学分析:electrochemical analysis
电解法:electrolytic analysis method
电重量法:electtogravimetry
库仑法:coulometry
库仑滴定法:coulometric titration
电导法:conductometry
电导分析法:conductometric analysis
电导滴定法:conductometric titration
电位法:potentiometry
直接电位法:dirext potentiometry
电位滴定法:potentiometric titration
伏安法:voltammetry
极谱法:polarography
溶出法:stripping method
电流滴定法:amperometric titration
化学双电层:chemical double layer
相界电位:phase boundary potential
金属电极电位:electrode potential
化学电池:chemical cell
液接界面:liquid junction boundary
原电池:galvanic cell
电解池:electrolytic cell
负极:cathrode
正极:anode
电池电动势:eletromotive force
指示电极:indicator electrode
参比电极:reference electroade
标准氢电极:standard hydrogen electrode
一级参比电极:primary reference electrode
饱和甘汞电极:standard calomel electrode
银-氯化银电极:silver silver-chloride electrode
不对称电位:asymmetry potential
表观PH值:apparent PH
复合PH电极:combination PH electrode
离子选择电极:ion selective electrode
敏感器:sensor
晶体电极:crystalline electrodes
均相膜电极:homogeneous membrance electrodes
非均相膜电极:hete
玻璃漏斗 Glass funnel long stem
试管 test tube test tube brush test tube holder test tube rack
蒸发皿 evaporating dish small
烧杯 beaker
锥形瓶 Erlenmeyer
量筒 grad cylinder
洗瓶 plastic wash bottle
勺皿 casserole ,small stoppered flask
分液漏斗 separalory funnel
warter bath/oil bath
strring bar
magnetic stirrer
冷凝器 condenser
Ballast bottle
圆颈烧瓶 Round-bottom flask
试剂瓶 reagent bottles
托盘天平 platform balance 台秤
〓疯子哥〓
第7楼2007/09/30
incident summary 事故摘要
incidental discharge 意外排放; 意外倾卸
incidental emission 意外排放
incidental release 意外释放; 意外排放
incineration plant 焚烧车间; 焚烧工厂
incinerator 焚化炉; 焚烧炉; 煅烧炉
incipient inhibition 初期抑制
incoming radiation 入射辐射
increased concentration of nitrates in water 水中硝酸盐浓度的增加
incremental cost 增量成本; 增支成本; 边际成本
indicator 指示剂
indicator 指示性化石
indiscriminate use of chemicals 滥用化学品
individual source 个别来源
indoor (air) pollutant 室内空气污染物
indoor air quality standard 室内空气质量标准
indoor air ventilation 室内通风
indoor climate 室内气候
inducer 诱导物; 诱发物
industrial accident 工业事故
industrial effluent treatment plant 工业废水处理厂
industrial wastewaters 工业废水
Industry and Environment (IEO) 工业和环境办事处
如需转载,请注明来自:
FanE『翻译中国』http;//www.FanE.cn
industry response time 工业反应时间
inert 惰性的
inertial collector 惯性集尘器
inertial separator 惯性分离器; 惯性除尘器
infauna 潜低性动物; 海底动物
infiltration 渗入; 渗透; 渗滤
infiltration rate 渗透速率; 渗滤速率
inflow of air 空气的流入; 进气
inflow of water vapour 水蒸气的流入
inflow pipe 进气管; 进水管; 流入管
influx of air 空气的流入; 进气
INFOCLIMA 世界气候资料情报检索服务
INFOTERRA 国际环境资料系统
infrared radiation (IR radiation) 红外辐射
infrared radiometer 红外辐射仪
infrared-absorbing gas 吸收红外线气体
inhibitant concentration 50 (IC 50) 半抑制浓度
initiator 引发剂; 起始物
injection into the atmosphere 排入大气; 注入大气
injection timing 喷油正时
injection well 注入井
injury 损害; 伤害
inlet swirl 进口旋流
in-line analysis 在线分析; 线上分析
INMARSAT 国际海事卫星组织
inorganic fluorine compounds 氟的无机化合物; 无机氟化合物
in-plant atmosphere 厂内空气; 厂内大气
in-plant recycling (of waste streams) 废水的厂内循环使用; 厂内重复使用
instrument measurements 仪器测定; 用仪器测量
instrumental (observation, record) 用仪器观测,记录
insulating foam 绝缘泡沫塑料
insulating substance 绝缘物质
insulation foam 绝缘泡沫塑料
intake manifold 进气歧管
intake port 进气口; 进气道
integrated environmental controls 综合环境控制
Integrated Glogal Ocean Services System 综合性全球海洋服务系统
integrated monitoring (IM) 综合监测
integrated ozone value 臭氧总值
inter(-)related (issues) 相关问题
intercalibration (of observational instrumentation) 观测仪器的相互校准
Intercomparison of Radiative Codes in... 气候模式中各种辐射数据编码的相互比较
intercooling of exhaust gas 废气的增压冷却; 废气的中间冷却
interfuel substitution 不同燃料相互取代
interglacial phase 间冰期
Intergovernmental Authority for Drought and Development 政府间干旱和发展管理局
Intergovernmental Oceanographic Commission (IOC) 政府间海洋学委员会
〓疯子哥〓
第8楼2007/09/30
Intergovernmental Panel on Climate Change (IPCC) 政府间气候变化问题小组
intermediate 中间体; 中间物
intermediate chemical 中间化学品
intermediate product 中间产品; 半成品; 半制品
intermediate radical 中间游离基; 瞬间游离基
intermediate species 中间物质; 瞬间物质
intermediate water 中层水; 中间水域
internal combustion (IC) 内燃
internal combustion engine 内燃机
internal wave 内波
International Association of Meteorology and Atmos... 国际气象学和大气物理学协会
international climate convention 国际气候公约
international climate fund 国际气候基金
International Commission on Cloud Physics 国际云物理学委员会
International Council of Environmental Law (ICEL) 国际环境法理事会
International Council of Scientific Unions (ICSU) 国际科学联合会理事会
International Data Rescue Co-ordination Centre (IDRCC) 国际资料抢救协调中心
International Drinking Water Supply and Sanitation Decade 国际饮水供应和卫生十年
International Environment Bureau (IEB) 国际环境局
International Environment Information System (INFOTERRA) 国际环境资料系统
International Environmental Education Programme (IEEP) 国际环境教育方案
International Geological Correlation Programme (IGCP) 国际地质对比方案
International Geophysical Year (IGY) 国际地球物理年
International Geosphere-Biosphere Programme (IGBP) 国际陆界生物圈方案
International Global Atmospheric Chemistry Project 国际全球大气化学计划
International Hydrological Programme 国际水文方案
International Institute for Environment and Development 国际环境与发展学会
International Lake Environment Committee 国际湖泊环境委员会
International Maritime Dangerous Goods Code 国际危险货物海运规则
International Maritime Satellite Organization (INMARSAT) 国际海事卫星组织
International Oceanographic Data Exchange (IODE) 国际海洋学资料交换所
International Ozone Commission 国际臭氧委员会
International Polar Year (IPY) 国际地极年
International Radiation Commission 国际辐射委员会
International Registter of Potentially Toxic Chem 可能有毒化学品国际登记中心
International Satellite Cloud Climatology Project (ISCCP) 国际卫星云气候学计划
International TOGA Project Office (ITPO) 热带海洋与全球大气实验计划国际办事处
International Tropical Timber Agreement 国际热带木材协定
International Tropical Timber Organization (ITTO) 国际热带木材组织
International Union for the Conservation of Nature.. 国际自然及自然资源保护联盟
International Union of Pure and Applied Chemistry 国际纯粹化学和应用化学联合会
International Workshop on Precipitation Measurement 国际降水测量讨论会
inter-relations 相互关系
intertropical convergence zone 热带幅合区
intrazonal soil 隐域土
intrusion 侵袭
inversion layer 逆温层
invisible radiation 不可见的辐射
involved area 受影响区域
IOC 政府间海洋学委员会
IODE 国际海洋学资料交换所
iodine(-containing) substance 含碘物质
iodofluorocarbons (IFCs) 碘氟碳化合物
ion balance 离子平衡
ion exchanger 离子交换剂
ion source 离子源
ion-exchange chromatography (IEC) 离子交换色谱法
ion-exchange resin 离子交换树脂
ionization chamber 电离室
ionization constant 电离常数
ionization detector 电离检测器
ionosphere 电离层
ion-selective electrodes 离子选择电极
IOS 综合性海洋服务系统管理的观测系统
IPA 异丙醇
IPCC 政府间气候变化问题小组
IPCC Trust Fund 政府间气候变化问题小组信托基金
IR radiation 红外辐射
IRC 国际辐射委员会
iron vitriol 铁矾; 青矾; 七水硫酸亚铁
IRPTC 可能有毒化学品国际登记中心
〓疯子哥〓
第9楼2007/09/30
impact assessment 影响的评价
impact statement 影响的报告
impact study 影响的研究
Impact Study Programme 影响的研究计划
impaction separator 惯性分离器
impactor 大气中悬浮微粒的取样器;
impairment 恶化; 损伤; 损害
impervious floor 不透水层
impervious layer 不透水层
impingement collector 冲击式收集器
impingement separator 冲击式分离器
impinger 大气中悬浮微粒的取样器;
import State 进口国
impoundment 拦蓄
impoundment 蓄水; 积水
improved technologies 改进过的技术
inactive 不活泼的; 钝性的
incentive 鼓励; 奖励; 鼓励性的; 奖励性的
incentive system for rational energy utilization (SIURE) 合理使用能源奖励制度
incident 意外; 事故
incident report 事故报告
diance 辐照度
irritant 刺激剂; 刺激物; 刺激性的
irruption 激剧繁增; 激剧繁殖
ISCCP 国际卫星云气候学计划
isolated source 孤立源
isolation of a pollutant 污染物分离
isoprene 异戊二烯
isopropanol 异丙醇
isopropyl alcohol (IPA) 异丙醇
isopsophic index 噪音指数
isotopic abundance 同位素丰度
ITA 综合性海洋服务系统管理的电信安排
item identification number 物品识别号码; 项目编号
ITPO 热带海洋与全球大气实验计划
ITTO 国际热带木材组织
IUCN 国际自然及自然资源保护联盟
jet(-)stream 急流
JOA 海洋学联合大会
Joint Agenda for Action 联合行动议程
Joint Oceanographic Assembly (JOA) 海洋学联合大会
〓疯子哥〓
第10楼2007/09/30
JSC 联合科学委员会
juvenile fish 幼鱼
katabatic wind 下吹风
ketones 酮; 酮类
killed lime 熟石灰; 消石灰
krypton-85 氪85
Kuroshio current 黑潮
label 标记; 标志
labelling 贴上标志; 标志; 标记
Laboratory for Atmospheric and Solar Physics (LASP) 大气和太阳物理实验室
lack of biologically mature trees 缺乏生物学上成熟的树木
lacustrine sedimentology 湖泊沈积学
LAER 最低可达排放速率
lag effect 滞后效应
LAGEOS 激光地球动力卫星
lagoon 氧化塘; 环礁; 泻湖
lahar 火山灰泥流
lake bloom 藻华
lakelands 湖泊地区
LAM 有限域模式
land area of the globe 全球大陆地带
land clearance 清理土地; 清除地物; 开荒
land clearing 清理土地; 清除地物; 开荒
land disposal of sewage sludge 下水污泥的地面处理
land disposal site 地面处理场
land erosion control 土地侵蚀控制; 土地侵蚀治理
land ice 陆冰
land masses 陆块; 地块
land pollutant 陆地污染物
land pollution 陆地污染; 土壤污染
land reclamation 土地改良; 土地开垦; 垦荒
land restoration 土地恢复; 土壤改良
land station [WWW] 地面站
land surface 地面
land surface temperature 地面温度
land treatment (of wastes) 废物的地面处理
land use 土地利用; 土壤使用
land-based sources 陆地来源的污染
landfill (site) 填地; 垃圾填埋地; 填埋
landfill dumping 倾弃垃圾填地
landfill treatment 垃圾填埋处理
landfilling 倾弃垃圾填地
land-ocean interactions 陆地海洋相互作用
Land-Ocean-Climate Satellite (LOCS) 陆地海洋气候卫星
landscape conservation 保护风景; 保护景观
landscape protected area 风景保护区
landscape renovation 景观改造; 风景更新
landscape restoration 恢复景观; 风景恢复
landscaped area 风景区
landslide 塌方; 山崩; 地崩
land-use mapping 绘制土地利用示意图
land-use plan 土地利用计划
land-use planning 土地利用规划
lapse rate 直减率; 递减率
large clearing 大面积砍伐森林; 大面积清除
large-area pollution 大面积污染
Large-scale Forest Damage Survey in Europe 欧洲大规摸森林损害调查
larval (crab, shrimp) 蟹虾的幼体
LASer FLuorescence EURope (Lasfleur) 欧洲激光荧光计划
Laser Geodynamic Satellite (LAGEOS) 激光地球动力卫星
laser station 激光站
Lasfleur 欧洲激光荧光计划
LASP 大气和太阳物理实验室
lateral transport 侧向输送; 侧向运送
latitude 纬度
latitudinal distribution 纬度分布
latitudinal zone 纬度地带
laughing gas (N2O) 笑气; 一氧化二氮
$$lc 致死浓度; 液相色谱法
$$lc 50 $$lc 50 半致死浓度; 一般不译
$$lc LO $$lc LO 最低致死浓度; 一般不译
LD 致死剂量
LD 50 LD 50 半致死剂量; 一般不译
leach field 沥滤场
leachate 沥滤液
leaching 沥滤
lead poisoning 铅中毒
lead time 产品从设计到投产的时间; 从订货到交货的时间
leaded 含铅的
lead-free 无铅的; 不含铅的
leaf drop 落叶
leaf necrosis 树叶枯死; 叶枯斑病
leaf season 长叶季节; 生叶季节
leaf surface 叶面
leaf-area index 叶面积指数
leak(age) (flow) rate 漏流速率; 渗漏速率
lean-burn engine 稀混合气发动机
leaner air-fuel ratio 更稀的空气燃油比
LEAP 较不发达国家备选能源规划系统
leaving group 离去基团
Less Developed Country Energy 较不发达国家备选能源规划系
统
