在hp 最新版本K版GSM中,对六价铬的描述是这样的: 3.9.1 Metallic applications: Hexavalent chromium and its compounds must not be present in any concentration in metallic applications (such as corrosion preventative coatings and conversion coatings). 3.9.2 Non-metallic applications: Hexavalent chromium and its compounds must not be present in concentrations greater than 0.1% (1000 ppm) by weight in any homogeneous material in non-metallic applications (such as paints, pigments, and plastics).
