何当奇
第5楼2008/07/16
1. Carrier flow is as per the value specified for your configuration. To check the carrier flow, put the injection mode in manual. Go back in «RUN» menu and watch the value. It is normal to have carrier flow deviation during a cycle. Between and before an injection the carrier flow must be correct.
载气流量按照你的仪器配置的设定值。检查载气流量,将进样模式改为手动。返回《运行》菜单并检查数值。通过这个标准,检查载气在常规状态下和分析周期期间两者之间的背离情况。在这之前,载气流量必须正确选择好。
载气流量以(分析仪)配置值而定。检查载气流量时,将进样模式设为手动。正常情况下,一个循环(或者周期)间,会有载气流偏差。进样前和进样间必须校正载气流。
