skyzhang521 2008/07/24
Microscopy and Microanalysis, Volume 10, Supplement S02, August 2004, pp 1004-1005 [img]https://www.instrument.com.cn/bbs/images/affix.gif[/img][url=http://www.instrument.com.cn/bbs/download.asp?ID=99975]Cs corrector for illumination[/url] 其它的无能为力拉 有些杂志都好偏阿
pplj82 2008/07/25
斑竹,第一篇文献你确定没有错误么? 我查的结果怎么是 Title: REFLECTION AND TRANSMISSION MATRICES FOR PLANAR BOUNDARIES BETWEEN ISOTROPIC DIELECTRICS AND CRYSTALS WITH DIFFERENT MAGNETIC PERMEABILITIES Author(s): DEPINE RA, GIGLI ML Source: OPTIK Volume: 96 Issue: 1 Pages: 13-19 Published: MAR 1994 没有16开始的页啊,还是我没查对?
蓝莓口香糖 2008/07/25
[quote]原文由 [B]pplj82[/B] 发表: 斑竹,第一篇文献你确定没有错误么? 我查的结果怎么是 Title: REFLECTION AND TRANSMISSION MATRICES FOR PLANAR BOUNDARIES BETWEEN ISOTROPIC DIELECTRICS AND CRYSTALS WITH DIFFERENT MAGNETIC PERMEABILITIES Author(s): DEPINE RA, GIGLI ML Source: OPTIK Volume: 96 Issue: 1 Pages: 13-19 Published: MAR 1994 没有16开始的页啊,还是我没查对?[/quote] 应该不是这个,楼主要的都是跟像差矫正有关的。
skyzhang521
第1楼2008/07/24
Microscopy and Microanalysis, Volume 14, Issue 01, February 2008, pp 2-15 Development of Aberration-Corrected Electron Microscopy
搂主 你这个贴转到文献求助版 比较好
skyzhang521
第2楼2008/07/24
Microscopy and Microanalysis, Volume 14, Issue 01, February 2008, pp 16-26 Contrast Transfer and Resolution Limits for Sub-Angstrom High-Resolution Transmission Electron Microscopy
skyzhang521
第3楼2008/07/24
Microscopy and Microanalysis, Volume 14, Issue 01, February 2008, pp 60-67 High-Resolution TEM and the Application of Direct and Indirect Aberration Correction
skyzhang521
第5楼2008/07/24
Microscopy and Microanalysis, Volume 10, Supplement S03, August 2004, pp 2-3 DESIGN OF AN ELECTRON OPTICAL SYSTEM FOR THE CORRECTION OF THE CHROMATIC ABERRATION CC OF A TEM OBJECTIVE LENS
skyzhang521
第7楼2008/07/24
Microscopy and Microanalysis, Volume 10, Supplement S02, August 2004, pp 1004-1005Cs corrector for illumination
其它的无能为力拉 有些杂志都好偏阿
pplj82
第8楼2008/07/25
斑竹,第一篇文献你确定没有错误么?
我查的结果怎么是
没有16开始的页啊,还是我没查对?
蓝莓口香糖
第9楼2008/07/25
怪味陈皮
第10楼2008/07/29
TEM的东西比较偏,在技术版面发求助成功的几率更高一些。
