poorlittle
第6楼2008/10/13
Just searched with “Thermometer, standardized” as keyword, 有点头绪了。
standardized : 似乎是将温度讯号(模拟显示)转为符合国际温标的数字显示, see http://www.wipo.int/pctdb/en/wo.jsp?IA=US1990003978&DISPLAY=DESC
for the range of use : 常用的温度量度范围
to the nearest 0.01°C: 而数字显示时, 修约至0.01°C. 即15.238°C要显示为15.24°C
standardized for the range of use to the nearest 0.01°C : 对常用的温度量度范围, 将温度讯号转换为符合国际温标的数字显示, 准确至0.01°C
standardized for the range of use to the nearest 0.01°C : 对常用的温度量度范围, 基于国际温标较准至0.01°C
这只是看了一两份资料後的猜测, 楼主最好贴出上下文。
poorlittle
第7楼2008/10/13
Thermocouple (热电偶) is one kind of thermometer. I found that “ASTM E 230-1998 Standard Specification and Temperature-Electromotive Force (EMF) Tables for Standardized Thermocouples” is translated as “ASTM E 230-1998 标准化热电偶用温度电动势(EMF)图表”.
standardized for the range of use to the nearest 0.01°C 可直译为 “对常用的温度量度范围, 进行标准化并准确至0.01°C”
What is 标准化? I am not sure whether it is the process of setting up the temperature scale by means of interpolation between certain "fixed points", such as the triple point of water (0.01 degree C), the boiling point of water (100 degrees C) , etc.
I think that I should throughout review the basic knowledge of temperature
poorlittle
第9楼2008/10/14
可能真的很简单, standardized 只是 calibrated 的同义词。
(见 http://www.icllabs.com/PET%20Thermometers.htm
7.8.2 Initial Calibration
Before initial use, and at least once a year thereafter, each portable electronic thermometer shall be re-standardized in a laboratory or other qualified calibration facility. The thermometer shall be re-standardized by comparing it at three or more temperatures with either a National Bureau of Standards (NBS) (ICL note: NBS is now NIST) certified thermometer or an equivalent thermometer with accuracy traceable to the NBS in accordance with the manufacturer's instructions. These standardization checks will ensure that accuracy is maintained within the limits given in Table 3.)
但为什么用standardized而不用calibrated? 行业习惯?
正在看温度计量的资料, 希望有答案。
何当奇
第10楼2008/10/14
这里应该含有标准化了的意思,所以用前者而不用后者。
不过具体没有用过温度计,只能是猜测
