The charge of Agilent engineers is high, inside two hours 940RMB will be payed, after two hours 450RMB per hour. The charge per hour is enough for my meal monthly... Thank you for you reply, Thanks
mhstin发表:i think is connectivity problems~~ u better call up Agilent engineers for solution. is free of charge.
