影子
第1楼2010/03/05
试译一下,仅供参考:
To establish a liquid chromatography/tandem mass spectrometry (LC-MS/MS) method for determining moxidectin in animal derived food. The sample cleaning-up method and test parameter were optimized in the method. Moxidection was extracted with acetonitrile and cleaned up with dispersive solid-phase extraction, and then detected by LC-MS/MS.
