化学中常见英语单词或词组的英文解释
专业英语
  • Acid
    A compound that yields H+ ions in solution or a solution with the concentration of H+ exceeding OH-.
    Acid ionization constant
    The equilibrium constant describing the degree of dissociation of an acid.
    Actinides
    The row of elements below the periodic table, from thorium to lawrencium.
    Alkali
    Synonym for base.
    Alkali metals
    The column of elements from lithium to francium.
    Alkaline earths
    The column of elements from beryllium to radium.
    Alkane
    A hydrocarbon without a double bond, triple bond or ring structure.
    Alkene
    A hydrocarbon with one or more double bonds and no triple bond.
    Alkyne
    A hydrocarbon with one or more triple bonds.
    Alpha particle
    A cluster of 2 protons and 2 neutrons emitted from a nucleus in one type of radioactivity.
    Anion
    An atom or molecule with a negative charge.
    Anode
    The negative electrode at which oxidation occurs.
    Aqueous
    Refers to a solution with water as solvent.
    Aromatic
    Refers to an organic compound with a benzene-like ring.
    Atom
    The smallest amount of an element; a nucleus surrounded by electrons.
    Atomic number
    The number of protons in the nucleus of the chemical element.
    Atomic weight
    The weight in grams of one mole of the chemical element; approximately the number of protons and neutrons in the nucleus.
    Avogadro's Law
    Equal volumes of gases contain the same number of molecules.
    Avogadro's Number
    6.02 x 1023 , the number of molecules in 1 mole of a substance.
    化学中常见英语单词或词组的英文翻译
    发贴支持新版开张
  • 该帖子已被管理者-happyjyl设置为精华,下面是奖励记录:加5积分,加5声望
  • 第6楼2005/12/24
    太好了,对我来说十分有用,谢谢!
