happyjyl
第1楼2010/07/01
原文的意思就是用A和B的峰面积之比啊。你可能没有理解“subtance: internal standard”的意思。这里的substance是指原料药(drug substance),与之对应的是成品(drug product或finished product)。“subtance: internal standard”就是药物比上内标。原文意思如下:
Peak area rations (subtance peak area: internal standard peak area) were evaluated for calculation of the standed curves.
