wccd(wccd) 发表:以下是某公司直读光谱仪的报警信息显示列表,在使用中常常会遇到,但有些意思仍无法能准确理解,所以请高手准确翻译出来,让大家分享:
0.ALARM ICS:Instrument busy ( exe-cuting M1,M2,IS,CS command )
1.ALARM# ICS:Instrument vacuum out
2.ALARM# ICS:Instrument temperature out
3.ALARM# ICS:Mains voltage out
4.ALARM# ICS:-1000 volt power supply out
5.ALARM# ICS:cabinet temperature out
6.ALARM# ICS:+5 volt power supply out
7.ALARM# ICS:+15 volt power supply out
8.ALARM# ICS:-15 volt power supply out
9.ALARM# ICS:+24 volt power supply out
10.ALARM# ICS:-100 volt power supply out
11.ALARM# ICS:-10v test out(ICS 35) / +5v SEQ out (ICS34/3520)
12.ALARM# ICS:-1v test out(ICS 35) / +15v SEQ out (ICS34/3520)
13.ALARM# ICS:-0.1v test out(ICS 35) / -15v SEQ out (ICS34/3520)
14.ALARM# ICS:charge converter zero reference out(ICS-35)
15.ALARM# ICS:CCS/DCU +350 Volt power supply out
16.ALARM# ICS:CCS/DCU +200 Volt power supply out
17.ALARM# ICS:CCS/DCU +15 Volt power supply out
18.ALARM# ICS:CCS/DCU -15 Volt power supply out
19.ALARM# ICS:CCS/DCU +5 Volt power supply out
20.ALARM# ICS:CCS/DCU +25 Volt power supply out
21.ALARM# ICS:Instrument safety circuit broken
22.ALARM# ICS:Instrument STOP button pressed
23.ALARM# ICS:Source not running
24.ALARM# ICS:Lower voltage out
25.ALARM# ICS:Charge converter overflowor underflow
26 ALARM# ICSata supplied to ICS out of range
27 ALARM# ICS:No instrument START
28 ALARM# ICS:Incorrect ACS Command sequence
29 ALARM# ICS:Reading attempted with no measure
30 ALARM# ICS:Power up instrument controller
31 ALARM# ICS:Link ICS-MSC USART-2,ICS Input buffer full
32 ALARM# ICS:Link ICS-MSC USART-1,ICS Input buffer full
33 ALARM# ICS:Autosampler timeout
34 ALARM# ICS:Command not exe-cuted bu ICS
35 ALARM# ICS:Link ACS-ICS USART-1,checksum error
36 ALARM# ICS:Illegal command received from ACS
37 ALARM# ICS:Link ACS-ICS USART-1,transmission error
38 ALARM# ICS:Illegal ACS string format to ICS
39 ALARM# ICS:Undefined status parameters on ICS
40 ALARM# ICS:Robot'breackdown' detected by ICS
41 ALARM# ICS:Link ICS-MSC USART-2,checksum error on MSC
42 ALARM# ICS:SEQ:ERR.GRATING 1 on
43 ALARM# ICS:SEQ:ERR.GRATING 2 on
44 ALARM# ICS:Optical filter carrousel unsynchronised
45 ALARM# ICS:Illegal optical filter nr selection
46 ALARM# ICS:SEQ:Invalid command
47 ALARM# ICS:SEQ:Lambda too high
48 ALARM# ICS:SEQ:M1:2 switchs on
49 ALARM# ICS:SEQ:M1:2 limit error
50 ALARM# ICS:M1 locked at SW1
