symmacros
第4楼2010/08/20
高能打拿极(HED)参考英文:
The HED/EM is current technology and is used in the 5973 and 5975. The high
energy dynode (HED) attracts the positively charged ions exiting the quadrupole.
When the ion beam hits the HED, electrons are emitted. The electrons are
attracted to the electron multiplier. The incoming electrons hit the inside surface
of the electron multiplier’s horn liberating more electrons from the surface. These
electrons cascade down the horn, ejecting more electrons with every impact.
Electrons produced by the HED cause the EM voltage to be lower (longer EM
life) when compared to the X-Ray/Electron Multiplier style systems.
Electrons, instead of ions, striking the EM do not remove as much of the EM
working surface (longer EM life) when compared to the X-Ray/Electron
Mid mass response (m/z 219) is greatly increased when compared to the XRay/
For increased signal, increase the electron multiplier gain. For highly concentrated
samples, decrease the electron multiplier gain
MS Basics and Hardware Configuration
High Energy Dynode/Electron Multiplier Detector
22
Be aware that the electron multiplier behaves as though it has a finite supply of
electrons. You may operate the electron multiplier at high sensitivity for a
relatively short duration. Alternatively, you may use the same electron multiplier
at a lower voltage value for a much longer time
