The only North American producer, Monsanto, marketed PCBs under the trade name Aroclor from 1930 to 1977. These were sold under trade names followed by a 4 digit number. The first two digits generally refer to the number of carbon atoms in the biphenyl skeleton (for PCBs this is 12), the second two numbers indicate the percentage of chlorine by mass in the mixture. Thus, Aroclor 1260 has 12 carbon atoms and contains 60% chlorine by mass. An exception is Aroclor 1016, which also has 12 carbon atoms, but has 42% chlorine by mass.。 这样看来1016和1242没啥区别了啊?没找到相关文献,不知有谁知道差异?
