Although I am not satisfied the current salary,but I will not choose job-hopping because of the present low salary.I think I should not live for money......Money, enough on the line.
Although I am not satisfied the current salary,I may still work in the present status. Salary is important, but work condition is also a key consideration, e.g. you may like this work, you go other place without this kind of equipment.
