气质自动调谐不过?求原因?盼解决
  • anranxiaohun
    2011/08/15
气质联用(GCMS)
  • 我用的是varian的320ms,三重四级杆的,最近我清洗了离子源,做了硬件诊断,都没有问题,但是自动调谐老是出错,找不到水峰,而且69的peak height也特别的低,具体数值在附件中,不知道到底是哪儿的问题,我已经拆装好几次了,希望得到大家的帮助
    ps:附件中我的调谐报告
  • symmacros
    第1楼2011/08/15
    Hardware diagnostics report for Varian Quadrupole Mass Spec
    Time: 10:39:37
    No errors detected. Proceeding with autotune.
    Tune report for Varian Quadrupole Mass Spec
    Time: 10:54:07    Tune file: FC-43 EI (Tuned on 15 Aug 2011)
    Ionization mode:EI Scan Optimization: Standard gc (Fixed detector)
    Exact Measured Peak Relative Peak Valley Resolution
    mass mass height height width
    (amu) (amu) (mV) (%) (amu @ 50%) (% of iso) (m/delta-m)
    18.0 18.1 0.865 5.790 0.89 76 20
    28.0 29.8 1.137 7.608 2.31 0 13
    Warning: the peak is very wide and mass shifted!
    69.0 68.9 4.886 32.700 0.81 91 85
    219.0 219.0 14.941 100.000 0.74 56 297
    502.0 501.9 2.504 16.757 0.78 49 644
    (Detector = 1620 V)
    Tuning of quad 1 in positive mode had the following error(s):
    Problem tuning m/z 28.0
    Time: 11:01:40    Tune file: FC-43 EI (Tuned on 15 Aug 2011)
    18.0 19.8 0.084 3.280 0.45 69 44
    Warning: the peak is very narrow and mass shifted!
    28.0 30.3 0.077 3.004 1.26 50 24
    69.0 70.1 1.180 45.922 3.25 18 22
    219.0 219.1 2.570 100.000 3.26 8 67
    Warning: the peak is very wide!
    502.0 501.1 0.493 19.176 3.40 11 147
    (Detector = 1620 V)
    Tuning of quad 3 in positive mode had the following error(s):
    Problem tuning m/z 18.0
    28 absolute size (mV - EDR on)
    - Limit 20.0 - Measured 0.0
    - OK!
    28/32 Ratio
    - Air 3.5:1 - Measured 0.0:1
    - OK! - Not indicative of Air
    28/18 Ratio
    - Limit 1.2:1 - Measured 0.0 :1
    - OK!
    - No significant leak detected -
    - OK -
  • symmacros
    第2楼2011/08/15
    三重四级杆没有过,知道的很少。请问楼主也检查一下有无泄漏?
  • 原天
    第3楼2011/08/15
    从你的调谐看是。不是峰太窄就是峰太宽。基峰是219.是不是你的聚焦透镜有问题啊?
  • 云靜風輕
    第4楼2011/08/16
    瓦里安的机器没有玩过,不知到跟安捷伦的调谐结果是否一样,看调谐结果,标样应该也是全氟三丁胺,安捷伦的要求的69,219,502的半峰宽在0.6左右。不知楼主的瓦里安是否也是这个要求。
    清洗离子源之后,再安装时,线路接得对不对啊,紧不紧啊!
    没有见到氧峰,不像是漏气。
  • 七宝
    第5楼2011/08/16
    是不是灯丝发射电流不足?或者是灯丝断了?
  • 穆紫冰
    第6楼2011/08/16
    是半峰宽大了点,
  • anranxiaohun
    第7楼2011/08/16
    谢谢大家的支持和帮助啦!
    1 标准品是FC-43,大概还有三分之一;
    2 目前仪器的真空度是2*e-7torr,瓦里安工程师要求5*e-6就可以做样,感觉这个真空度也可以;
    3 灯丝做了硬件检测,没有问题;
    4 各个透镜我拆下来好几遍,觉得哪儿没有接错啊,我是女生,已经用我的最大力气把该紧的地方都紧过了;
    5 咨询工程师,工程师说有可能漏气,检查也没有什么漏气啊
    6 现在唯一没有检查的是氦气,因为氦气现在剩下不多了,不知道会不会因为气体少了不纯了,导致自动调谐不过呢?
    try and try again until ok!
  • 老高
    第8楼2011/08/16
    把你以前正常的调谐报告放一份上来看看。
    是不是灵敏度比正常时低很多呢?清洗离子源时还动了些什么,比如灯丝的位置?能回忆起来吗?
    从你的描述看,与调谐液,真空度,氦气可能关系不大。
  • 老高
    第9楼2011/08/16
    灯丝的硬件检测是怎么检的?报告也发一下看看。请问您使用仪器多长时间了,离子源清洗过多少次了?
    Q1中28太奇怪,峰位偏移很大,分辨也很差。
    Q3中高质量端分辨很差,低质量端峰位偏移大。
  • anranxiaohun
    第10楼2011/08/16
    附件中是我拆离子源之前,做的调谐报告,那时候我觉得还可以
    老高(gaoweimass) 发表:把你以前正常的调谐报告放一份上来看看。
