衍生化试剂BSTFA+TMCS的用量和比例 各位老师帮帮忙,小弟是新手 EP药典上苯丁酸钠杂质c的检测方法是做气相顶空。先用二氯甲烷萃取,蒸干后,再加硅烷化溶液进行硅烷化,具体方法如下: Silylation solution. To 2 mL of N,O-bis(trimethylsilyl)tri- fluoroacetamide R add 0.04 mL of chlorotrimethylsilane R and mix. Test solution.Dissolve50.0mgofthesubstancetobeexamined in 3 mL of water R and add 0.5 mL of hydrochloric acid R. Extract with 2 quantities, each of 5 mL, of methylenechlorideR. Evaporate the combined methylene chloride extracts to dryness in a vial with a screw cap and add 0.5 mL of the silylation solution.Sealthevialandheatat70±5°Cfor20min.
