这是有关峰判定的章节,总感觉不对劲,内行人指点下,怎样将字义理顺些。 Shifting the peak beginning 移位峰开始 The Start command or icon defines a new position of the peak beginning. In the event the peak beginning is shifted before the end of the preceding peak, a vertical line will separate those peaks and its position will coincide with the new peak beginning. If the peaks are separated by a vertical line or connected at the valley and the peak beginning is shifted closer to the apex, the peaks will be separated.
