附件:
雾非雾
第6楼2013/05/28
Chemical Description and Physical Properties: Colorless to white solid in various forms.
molecular formula: C6Cl6
molecular weight: 284.76
boiling point: 323-326°C
vapor pressure: 0.001 Pa @ 20°C
melting point: 231°C
Analytical Method:
sampling media: Glass Fiber Filter (37 mm)
analytical solvent: Toluene
maximum volume: 480 Liters maximum flow rate: 2.0 L/min
current analytical method: Gas Chromatography; gc/ECD
method reference: OSHA SLTC In-House File
Gas Chromatography | EPA Method 525.2: Organic compounds in Drinking Water on ZB-5 on ZB-5 | Zebron™ ZB-5, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | 8270 Semi-Volatile Organic Analysis on ZB-5 | Zebron™ ZB-5, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Semivolatiles (BNA) by gc/MS (EPA Method 8270C) | Zebron™ ZB-5, gc Cap. Column 30 m x 0.25 mm x 0.50 µm, Ea |
Gas Chromatography | EPA Method 505 - Organohalide Pesticide Mix | Zebron™ ZB-1, gc Cap. Column 30 m x 0.32 mm x 1.00 µm, Ea |
