Al-Cit和A-Cf是什么?
  • 翯翯清秋
    2013/12/12
  • 一篇英文文献里面有Al-Cit和A-Cf两种用来检验铝的形态,是什么意思?!
  • 该帖子已被版主-zhaohua8011加2积分,加2经验;加分理由:鼓励新人
  • zhaohua8011
    第1楼2013/12/12
    最好能将文献片段上传,不然这样很难分析!
  • 翯翯清秋
    第2楼2013/12/13
    您好!以下是部分原文
    Taking Al-Cit and Al-Tf as model species for small-molecule
    and large-molecule Al species, respectively, the retention behaviors
    of different Al species on CHAPS modified C18 column were further
    investigated by on-line ICP-MS detection, the chromatograms
    were shown in Fig. 3. As could be seen, the retention times on
    the modified C18 column were about 2.72 min for Al-Cit and
    2.36 min for Al-Tf, which was consistent with the results obtained
    by UV detection. Further studies indicated that the recoveries
    for small-molecule Al-complex compounds and large-molecule
    zhaohua8011(zhaohua8011) 发表:最好能将文献片段上传,不然这样很难分析!
  • zhaohua8011
    第3楼2013/12/13
    Al-Cit代表小分子络合铝
    Al-Tf 代表大分子蛋白铝
