1、ISO 17129 Milk powder -- Determination of soy and pea proteins using capillary electrophoresis in the presence of sodium dodecyl sulfate (SDS-CE) -- Screening method (2012)
5、(ASTM D7881, Test Method for Determination of 4-Caraboxybenzaldehyde and p-Toluic Acid inPurified Terephthalic Acid by High Performance Capillary Electrophoresis with Reverse Voltage Mode;
6、ASTM D7882, Test Method for Determination of 4-Caraboxybenzaldehyde and p-Toluic Acid inPurified Terephthalic Acid by High Performance Capillary Electrophoresis with Normal Voltage Mode;)
5、(ASTM D7881, Test Method for Determination of 4-Caraboxybenzaldehyde and p-Toluic Acid inPurified Terephthalic Acid by High Performance Capillary Electrophoresis with Reverse Voltage Mode; 6、ASTM D7882, Test Method for Determination of 4-Caraboxybenzaldehyde and p-Toluic Acid inPurified Terephthalic Acid by High Performance Capillary Electrophoresis with Normal Voltage Mode;)
