【求助】有关j积分仪器使用说明的英语翻译,有兴趣的朋友过来帮我看看,谢谢了
  • stevenlang
    2006/09/12
专业英语
  • An area slice is bounded by the start time of the slice,the start time plus the slice width,the analoy (voltage)signal ,and a reference
    voltage .The Integegrator uses a slice width of 0.05 seconds (20 slices per second)and an electrical reference of approximately 0
    voltage.
  • 一抹冰蓝
    第1楼2006/09/13
    (积分)片断的面积受片断的起始时间、起始时间加上宽度、analoy(电压)信号及参比电压的限制。Integegrator采用0.05秒的片断宽度(20片断/秒)以及大约0伏的参比电压。
    仅供参考。关于slice,analoy,integerator的翻译,还需楼主根据专业术语及上下文来判断理解。
    stevenlang 发表:An area slice is bounded by the start time of the slice,the start time plus the slice width,the analoy (voltage)signal ,and a reference
    voltage.
