安平
第1楼2021/11/16
shimadzu的谱库文件由多个文件组成。标准谱库和用户自检谱库的文件类型有所不同。
*.lib是主文件
*.spc 存放质谱图
*.fom 存放分子式
*.name 存放组分名称。
下面引自说明书
NIST20-1.LIB Includes header information about the NIST Library and compound information, including molecular weights and CAS registration numbers.
NIST20-1.FOM Contains compound composition formulas.
NIST20-1.SPC Contains spectra information for compounds. It uses it to calculate the similarity index by the similarity search.
NIST20-1.NAM Contains compound names.
NIST20-1.STR Contains molecular structures of compounds.
NIST20-1.NCV Contains index information to facilitate access to the database.
NIST20-1.ADD Contains spectra information for compounds. It uses it in the display and the report of the search result.
NIST20-1.C2S Contains index information referred to molecular structure in this library from private library.
symmacros
第2楼2021/11/16
非常感谢安平老师!
