colray
第4楼2024/08/15
以下从E文网站找到两个案例,不知道可有用:
1.电气干扰:Base Line Plateaus - electrical interferences? - Forum - GC/MS - Agilent Community
2. we had the same problem in our lab. In our case, the baseline was randomly jumping up or down for a random amount of time and in a totally irreproducible way. So we cleaned the source, swapped the source, installed a new multiplier, cleaned the HED, cleaned the quadrupol, switched out the HED power supply cable, the electronic board on the side of the analyzer door, the complete analyzer, the electronics under the analyzer...
The problem seemed to have been gone after a few of these steps, but returned a few days later. Finally, we switched the foreline vacuum pump. Success! The vacuum had been inconsistent, possibly because of a leak somewhere in the foreline pump. The baseline has been stable since then. So, if your baseline starts jumping again, you might want to check or replace the foreline pump.
我们的实验室也遇到了同样的问题。在我们的例子中,基线是在随机的时间内随机上升或下降,并且以一种完全不可复制的方式。因此,我们清洁了离子源,切换了离子源,安装了新的电子倍增器,清洁了HED,清洁了四极杆,换掉了HED电源线,质谱仪门侧面的电子板,完整的分析仪,分析仪下方的电子设备......
在执行了几个步骤后,问题似乎已经消失了,但几天后又回来了。最后,我们切换了前级真空泵。成功!真空度不一致,可能是因为前级泵的某处存在泄漏。自那时以来,基线一直保持稳定。因此,如果您的基线再次开始跳跃,您可能需要检查或更换前级泵。
