高分子膜截面的制备以及扫描电镜表征
刘士新1田娜娜1刘娜1黄禹琼1方卉1梁国弘1魏俊1赵权1靳凤民1*
(1天津大学化工学院,天津300072)
摘要:
高分子膜具有高分离性能、低能耗、无相变和环境友好等优点,广泛用于水处理分离、离子交换、气体分离、医用、光电、特种物质的分离。对于基底是高分子材料的截面制备比较难,直接在液氮中很难脆断。下面以反渗透膜(RO HPAFR)、自聚微孔聚合物(PIM)、沉积了聚多巴胺的纳滤膜三种膜材料为例,采用三种方法对样品进行截面处理,从三种方法中得到在液氮中用手术刀处理截面可以得到理想效果,提高了制样成功率。本研究为扫描电镜膜截面样品形貌表征提供了一个经济、方便且有效的参考途径。
关键词 高分子膜;截面制备;手术刀;扫描电镜
中图分类号:TH742
Preparation and Scanning Electron Microscopy Characterization
of Polymer Membrane Cross Section
LIU Shixin1 , TIANNana1 , LIU Na1 , HUANG Yuqiong1 , FANGHui1 , LIANGGuohong1 , WEIJun1 , ZHAOQuan1 , JINFengmin 1*
(1 School of Chemical Engineering and Technology, Tianjin University, Tianjin)
Abstract:Polymer membranes have the advantages of high separation performance, low energy consumption, no phase change, and environmental friendliness, and are widely used in water treatment separation, ion exchange, gas separation, medical, optoelectronic, and separation of special substances. It is difficult to prepare cross-sections with polymer materials as the substrate, and it is difficult to break them directly in liquid nitrogen. Taking reverse osmosis membrane (RO HPAFR), self polymerized microporous polymer (PIM), and nanofiltration membrane deposited with polydopamine as examples, three methods were used to treat the cross-section of the samples. Among the three methods, it was found that using a surgical knife to treat the cross-section in liquid nitrogen can achieve ideal results and improve the success rate of sample preparation. This study provides an economical, convenient, and effective reference approach for characterizing the morphology of scanning electron microscopy membrane cross-section samples.
Keywords polymer membrane;cross-sectional preparation;surgical knife; scanning electron microscope
引言
扫描电镜观察不限于样品表面,为了研究样品的内部结构,测定镀膜厚底、元素扩散、填料是否均匀等,必须将样品断开,露出截面,将断口面朝上安装,在电镜中观察成像图片。扫描电镜是目前观察膜结构,尤其是观察影响分离特性的表面及皮层结构的有效工具。按照原料分类,膜分为有机膜和无机膜[1]。有机膜的主要原材料是各种高分子材料。对于高分子材料的扫描电镜截面样品制备一般采取冲断和脆断(低温下)来获得断口。但是在实验中发现有一类膜在液氮中浸泡后韧性较强无法脆断,很难对膜截面形貌进行表征[2, 3]。本文针对这类膜截面制样方法进行了摸索,取得了一种方便研究者截面制备实验样品的方法。
1常规制样方法
常规的膜样品制备一般是将样品放在液氮中浸泡一段时间后,再用镊子夹住膜的两侧,在液氮中将膜折断,进行扫描电镜表征(如图1)。但是对于聚丙烯纤维为基底的膜状样品由于其具有纤维方向杂乱,作用在每根纤维上的力被分散且力的方向各向异性,导致聚丙烯纤维膜在液氮中浸泡后韧性较强很难脆断。直接用剪刀剪断会破坏原有结构,下面采用经验技巧来解决这种问题。
图1 样品制备流程图
2制样方法改进
2.1实验方法
反渗透膜是分离膜的一种,是在高于溶液渗透压的操作压力作用下,截留溶解性盐、胶体、微生物和大分子有机物来进行水质纯化[4-6]。反渗透膜由分离层、超滤层、无纺布三层膜结构组成。下面采用反渗透膜(RO HPAFR)来进行方法试验。下述方法全过程都在液氮中完成。
方法 a:将膜在液氮中浸泡10min左右,用镊子固定膜的一侧,用剪刀将膜剪断,如图2a。
方法 b:用剪刀先将膜样品断开大部分,预留 1mm左右区域,将膜在液氮中浸泡10min左右,用镊子夹取膜的两侧在液氮中拉断,如图2b所示。
方法 c:将膜浸泡在液氮中10min左右后,用镊子将膜在液氮中固定,用直头手术刀从基膜一侧将膜快速划开,如图2c所示。
方法d:直接用剪刀将膜断开,如图2d所示。
图2截面样品制备方法
2.2实验分析
使用a方法得到的膜截面扫描电镜图像如图3(a1~a3),在液氮中剪断的膜整体有一定的结构破坏,但部分区域上表面是自然脆断的,可以看出膜的底层为聚丙烯纤维压制的基膜,中层超滤层是聚砜多孔膜。对中层区域的上表面继续放大后可清晰地看出一层由间苯二胺和1,3,5-均苯三甲酰氯反应得到的聚合物聚酰胺层,厚度大约为200~400nm左右。
使用方法b自然断裂的区域虽然尺寸为极小部分但是能够满足对样品上表面扫描电镜的表征需求。但是膜的中间超滤层和基膜分界不清楚,且膜截面的纤维散开,虽然可以用于观察膜的部分形貌,但测试结果不理想如图3(b1~b3)。
使用方法c的膜截面断口的三层截面结构和每层膜的形貌清晰可见如图3(c1~c3)。
使用方法d直接用剪刀断裂的膜截面断口结构受到严重的破坏,如图3(d1~d3)。
对比4种方式,制样方法a,b,c都可以得到分离层的结构,但是剪刀剪和部分剪刀剪后的基膜会有结构坍塌,纤维结构破损的状况出现。方法d无论哪一层都无法分解清楚。使用方法c采取手术刀可以得到扫描电镜测试结果更理想。
图3反渗透膜四种制样方法获的扫描电镜膜截面图
3 制样改进方法的适用性
为验证上述制样技巧适用性,选取另外两种不同膜截面进行扫描电镜表征,膜1为三层膜结构的纳滤膜,第一层是由聚丙烯(PP)纤维压制而成,第二层为超滤层聚砜构成的,在超滤层聚砜上制备一层聚酰胺层。聚酰胺层是先沉积的聚多巴胺,然后再进行哌嗪和1,3,5-均苯三甲酰氯反应得到的复合而成。膜2是聚酰亚胺纳米纤维膜PIM,一种由有机高分子和无机物质通过化学键合成或者物理相互作用形成的新型复合材料。有三层膜材料,最上面一层是高分子自聚微孔聚合物,中间层是聚合物基底聚丙烯腈,具有非对称指状孔,最下面一层是由聚丙烯(PP)和聚酯(PET)颗粒压制而成。将两种膜采用手术刀在液氮中直接切割的方法制备膜断口。最后得到的拍照结果如下图四。
3.1实验分析
膜1用方法c得到的扫描电镜截面形貌如图4(b1~b3)中间层多孔结构和孔分布均匀情况清晰可见。多孔结构的下方聚丙烯(PP)可以清楚的看到较齐整纤维断口,多孔结构的上层聚多巴胺层,也可以看到厚度约为160nm左右的致密层且具有较好的连续性。图4(a1~a3)使用剪刀的的形貌图可以看到,截面整体坍塌严重不能看到各个膜层的分界面。
膜2采用方法c 得到的电镜图4(d1~d3),可清楚的看到PIM中间层近内表面层有大的类指孔,近外的表层有小的类指孔,在两个类指孔之间有个类海绵状的构型[7, 8]。小的类指孔上面一可以清楚的看到280nm致密层。而用剪刀直接剪断后可以看到破坏最上层,使致密层向里内弯如图4c1,剪刀的应力使上层薄膜破碎如图4c3。
图4两种膜材料用制样技巧和普通方法的扫描电镜膜截面图
4结论
采用物理降温的方法将新鲜标本冷冻再进行切片的原理改进高分子膜的制备方法。经过实验可知直接在液氮中用手术刀将膜样品划开可以得到分界清楚的膜界面。此方法可以解决此类高分子膜材料的断口截面制备的问题,既方便又可以节约成本。
参考文献
[1] 尤金德. 中国功能膜行业现状及发展思路[J]. 中国石油和化工经济分析. 2013(11): 49-52.
[2] 黄艳萍,黄文浩,孙晓洋. 光伏镀膜玻璃膜层的扫描电镜成像分析[J]. 分析仪器. 2024(02): 33-37.
[3] 陈茜,李少杰,丛铁,等. 基于扫描电镜表征膜截面样品的制样技巧[J]. 电子显微学报. 2022, 41(02): 194-198.
[4] 杨兰娜蔡海林郑领英姜静颖王志余. 电镜观察反渗透膜及气体分离膜的微细结构[J]. 水处理技术. 1992(06): 32-36.
[5] 孙雪,杨楠,陈文宜,等. 反渗透膜元件在废水零排放多级浓缩系统中的应用[J]. 石化技术. 2024, 31(06): 83-85.
[6] 曹立群,王海棠. 污水处理中反渗透水处理设备的应用[J]. 现代盐化工. 2024, 51(03): 110-112.
[7] 刘淑秀,吴玲玲,蒋贺丁,等. 聚砜酰胺超滤膜的形态结构[J]. 膜科学与技术. 1983(01): 41-46.
[8] 徐协卿. 扫描电镜(SEM)研究聚砜仿制的中空纤维超过滤膜[J]. 膜科学与技术. 1985(01): 47-51.
