【求助】中译英,那位帮帮忙?!
专业英语
  • 要把中文的标准翻译成英文的,那位TX帮帮忙阿?
    以缓冲盐溶液(0.01mol/L KH2PO4+0.005mol/L EDTANa2溶液,以磷酸调节pH值至4.0)-乙腈(80:20)为流动相,流速1.0ml/min,柱温35℃,检测波长275nm,进样量60µL为色谱分析条件,分别对标准溶液及待测样液上机分析。
    汗,英语实在是太菜了,
  • 遨翔的岁月
    第1楼2007/11/21
    To buffer salt solution (0.01 mol / L KH2PO4 +0.005 mol / L EDTANa2 solution to regulate phosphate pH to 4.0) - acetonitrile (80:20) as the mobile phase flow rate of 1.0 ml / min, temperature 35 ° C, detection wavelength 275 nm, injection of 60 µ L conditions for the chromatographic analysis, and standard solutions were measured on the kind of liquid on the plane。
  • 该帖子已被版主-何当奇加1积分,加2经验;加分理由:热心助人
  • 闲鹤野云
    第2楼2007/11/21
    The standard solution and test soultuon were analyzed respectively, using buffer (0.01 mol/L KH2PO4 +0.005 mol/L EDTANa2 solution, which was adjusted to pH4.0 with phosphric acid)-acetonitrile (80:20) as the mobile phase at flow rate of 1.0 ml / min, under temperature of 35 ° C, detection wavelength of 275 nm, and injection vilume of 60 µ L.
  • 该帖子已被版主-何当奇加2积分,加2经验;加分理由:应助
  • houruirui
    第3楼2007/11/22
    谢谢了,上面的TX,你们是我的榜样
  • happyjyl
    第4楼2007/11/22
    Mobile phase: buffered salt solution (0.01mol/L KH2PO4 and 0.005mol/L EDTANa2, adjusted to pH4.0 with phosphoric acid)-acetonitrile (80:20)
    Flow rate: 1.0ml/min
    Oven temp.: 35℃
    Wavelength: 275nm
    Sample injection volume: 60µL
    Inject the standard solution and test solution respectively.
  • yu.ge
    第5楼2007/12/02
    流动相: 缓冲的盐水(0.01mol/L 磷酸二氢钾和0.005mol/LEDTANa2, pH4.0 用磷酸调整) 乙腈(80:20)
    流速: 1.0ml/min
    温度: 35℃
    波长: 275nm
    样品射入容量: 60.L
    注射标准溶液和测试样品。
    happyjyl 发表:Mobile phase: buffered salt solution (0.01mol/L KH2PO4 and 0.005mol/L EDTANa2, adjusted to pH4.0 with phosphoric acid)-acetonitrile (80:20)
    Oven temp.: 35℃
    Wavelength: 275nm
