大致意思就是如此,各位高手替我看看,还有什么补充完善的。谢谢各位。 The sample purging conditioning system maintains a sample in the gaseous phase and passes the sample through transport tubing to the sample valve. The sample flows through the sample loop to the sample vent. helium is then diverted through the loop to transport the sample into the system for analysis. 样品通过一个样品阀,对分析取样系统进行吹扫。 样品通过一个样品取样环后,然后放空。 氦气随后将定量环中的样品气输送进样品分析系统。
chengjingbao发表:大致意思就是如此,各位高手替我看看,还有什么补充完善的。谢谢各位。 The sample purging conditioning system maintains a sample in the gaseous phase and passes the sample through transport tubing to the sample valve. The sample flows through the sample loop to the sample vent. helium is then diverted through the loop to transport the sample into the system for analysis. 样品通过一个样品阀,对分析取样系统进行吹扫。 样品通过一个样品定量管后,然后放空。 氦气然后将定量管中的样品气输送进样品分析系统。
chengjingbao发表:大致意思就是如此,各位高手替我看看,还有什么补充完善的。谢谢各位。 The sample purging conditioning system maintains a sample in the gaseous phase and passes the sample through transport tubing to the sample valve. The sample flows through the sample loop to the sample vent. helium is then diverted through the loop to transport the sample into the system for analysis. 样品通过一个样品阀,对分析取样系统进行吹扫。 样品通过一个样品取样环后,然后放空。 氦气随后将定量环中的样品气输送进样品分析系统。
