去年冬天
第1楼2009/06/06
Centre Court,
Meridian Business Park, Leicester,
LE19 1WD, United Kingdom
Telephone: +44 (0) 116 263 0330
Facsimile: +44 (0) 116 263 0311/12
www.intertek.com/consumergoods
Intertek Labtest UK Ltd
Registered in England No. 3287320 Registered Office: 25 Savile Row London W1S 2ES
TEST REPORT
NUMBER: LECH00241811C
PAGE 1 OF 2
APPLICANT: Carte Blanche Greeting Ltd
PO Box 500
Chichester
West Sussex
PO20 2XZ
DATE: 24th December 2008
For the attention of Steve Brooker
SAMPLE DESCRIPTION: Up Up and Away – Snow globe
REFERENCE / STYLE NO.: 40429
RETAILER: Not Specified
SAMPLE RECEIVED: 27th November 2008
PURCHASE ORDER: 45432
TEST REQUEST: ^Microbiological Analysis
CONCLUSION: The microbiological test results were within typical levels for this type of product.
Tests marked (^) in this Test Report have been sub-contracted to an agent approved by Intertek.
Opinions and interpretations expressed herein are outside the scope of UKAS Accreditation.
Centre Court,
TEST REPORT
PAGE 2 OF 2
MICROBIOLOGICAL ANALYSIS
Sample Description:
Parameter Actual Result (cfu/g)
T.V.C./g @ 30°C for 48 hours < 10 cfu/g
Coliform Organisms / g ** < 10 cfu/g
E.coli / g Not Detected
Staphylococcus aureus / g < 20 cfu/g
Clostridium perfringens / g < 10 cfu/g
Yeasts / g < 10 cfu/g
Moulds / g < 10 cfu/g
(** Presumptive count only)
END OF REPORT
poorlittle
第6楼2009/06/07
我只是不解, 为什么楼主不先在Google搜一下。
“E. coli“在Google第一页就有了, ( http://www.google.com.hk/search?hl=zh-TW&q=E.+coli&btnG=%E6%90%9C%E5%B0%8B&meta=lr%3Dlang_zh-CN%7Clang_zh-TW&aq=f&oq= ), 用 “mould, cfu” 在Google搜, 第一页也有答案了 (http://www.google.com.hk/search?hl=zh-TW&q=mould%2C+cfu&btnG=%E6%90%9C%E5%B0%8B&meta=lr%3Dlang_zh-CN%7Clang_zh-TW&aq=f&oq
闲鹤野云
第7楼2009/06/07
[/quote]
太懒了,还是其他目的,宣传......
