天晴了
第3楼2011/04/11
移液管
当指定使用移液管时,可以用合适的滴定管代替。当指定使用“装盛”移液管时,可以用合适的容量瓶代替。
在分析化学实验中,要求准确量度体积时一般使用移液管、滴定管和容量瓶.这些仪器在制造时都要进行校正再标上刻度,但校正时所标的刻度有两种不同涵义,一种是指“排出”(to diliver,简写TD),另一种指“装盛”(to Contain,简写TC)。装盛体积和排出的体积是不一样的。
校准类型
“TC, In”:
内含液体的量符合仪器的标称量程
(如,刻度量筒与容量瓶)。
“TD, Ex”:
排出液体的量符合仪器的标称量程
(如,移液管与滴定管)。
to contain 不知道怎样翻译比较准确。
影子
第4楼2011/04/12
在药典上找了好久,终于找了几个例子供大家参考,看看能不能有助于理解:
Nonvolatile residue— Using a “to contain” pipet, transfer 1.0 mL onto 3 to 5 g of sand spread in a shallow layer in a stainless steel dish, the dish and sand having been previously dried and weighed. Rinse the pipet, with several small portions of water, onto the sand.
Chloride content— Using a “to contain” pipet, transfer 10.0 mL of Injection into a 150-mL beaker, rinsing the pipet into the beaker with several small portions of water.
Assay preparation— Using a “to contain” pipet, transfer an accurately measured volume of Injection, equivalent to about 100 mg of iron, to a 200-mL volumetric flask. Dilute with Calcium chloride solution to volume, and mix. Pipet 2.0 mL of this solution into a 250-mL volumetric flask, dilute with Calcium chloride solution to volume, and mix.
本来以为与量入式或量出式移液管有关,但不知道怎么又与容量瓶扯在一起,所以就想不出所以然了
poorlittle
第7楼2011/04/12
Is this one?
http://www.google.com.hk/images?q=%E2%80%9Cto+contain%E2%80%9D+pipet&hl=zh-CN&safe=strict&gbv=2&tbm=isch&ei=j1akTeWKMoWmuAOy6-n2CA&start=20&sa=N
http://www.capitolscientific.com/estylez_item.aspx?item=P6035-12
http://www.sks-science.com/lab-supply-p-9514.html
http://www.smallparts.com/Kimble-Kimax-Disposable-Microcapillary-Contain/dp/B002RS5L1Q
影子
第8楼2011/04/12
嗯,就是这个东东
poorlittle
第10楼2011/04/13
“to contain” pipet seems to be 量入式移液管
The difference between “to contain” and “to deliver” seems to be the location of the zero mark (i.e. at the top or at the bottom).
Information :
http://www.zhku.edu.cn/zhongxin/xnsys/cyblyq/kejian/a07/a07.htm
Please click the text in blue !!!
……滴定分析中所使用的吸量管必须符合GB 12807-91规定的要求。
移液管是量出式(Ex)计量玻璃仪器,吸量管有量出式和量入式两种;……
