X荧光光谱仪部分常用备件 | |
名称 | 订货号 |
Teeth Belt (Spinner) | 5322 358 31208 |
Teeth Belt (Turret) | 5322 358 31207 |
Photo Interruptor | 5322 693 11078 |
O-Ring Viton 2.62x69.52 (50× Shore) | 5322 530 50613 |
O-ring RUBB 58.42x2.62 | 5322 530 51298 |
Blade Spring | 5322 492 71289 |
Back up Ring | 5322 530 50713 |
Quad Ring | 5322 530 50708 |
Pneumatic Actuator CP95SDB32-100 | 5322 790 00501 |
Pneumatic Actuator RM8026/50 | 5322 360 40503 |
Coupling | 5322 739 00021 |
1Q DC Motor | 5322 361 21563 |
2Q DC Motor | 5322 694 15221 |
Spinner Motor | 5322 785 01501 |
Turret Motor, Maxom with tacho | 5322 694 15554 |
Quad Ring Minn 4009 | 5322 532 52395 |
Backup Ring For Quad Ring 4009 | 5322 530 50874 |
Flanged seal | 5322 535 71317 |
Quad ring Minn 4009 | 5322 532 52395 |
Backup ring for Quad ring Minn 4009 | 5322 530 50874 |
Vacuum Pump Edwards Type RV8 | 5322 360 20126 |
Vacuum Pump Edwards Type RV3 | 5322 360 20125 |
Fluor Rubber Hose 6.6x3.4x500 | 5322 530 20516 |
Detector cable hose clip (Flow detector) | 5322 492 71593 |
Detector cable hose clip (Scint. detector) | 5322 492 63371 |
Set of 5 Windows: | |
2 Micron | PW2417/02 |
1 Micron | PW2417/01 |
Tube light TL 13W | 5322 694 15543 |
Fan | 5322 785 03301 |
Fan | 5322 361 10985 |
Fan and Wiring | 5322 694 15541 |
Lamp 12V 3W | 5322 134 80205 |
Tin Al oxide pellets | 5322 390 84003 |
Apiezion M. 25g Tube | 5322 390 20145 |
HT-Silicon Grease | 5322 390 20011 |
Vacuum Oil Ultragrade 19 | 5322 390 10098 |
Filter Water | 5322 480 54034 |
C3 Test Sample | 5322 397 10133 |
Water flow meter 0.2-6 l/min | 5322 349 20147 |
PROCON water pump | 5322 784 00011 |
Detector gas control board | 5322 694 15235 |
CPU2000 board | 5322 790 00921 |
Spectrometer T2 control board (SPECTRT-CNTR) | 5322 790 00911 |
Spectrometer M control board (SPECTRO-M-CONTROL) | 5322 785 01511 |
Spinner changer interface board (SCI) | 5322 790 00941 |
Position control board (POSCON2) | 5322 694 16023 |
Dual multi-channel analyzer board (DMCA) | 5322 790 00931 |
Low voltage power supply LPQ172 | 5322 785 01461 |
Low voltage power supply LPS255-C | 5323 785 00101 |
仗剑少年游
第2楼2013/08/25
楼主名称音译为帕纳科,难道是官方人士?还是用户?
X荧光光谱仪部分常用备件 | |
名称 | 订货号 |
