未知物定性求助!
  • 百万个为什么
    2018/07/24
气质联用(GCMS)
  • 悬赏金额:20积分状态:已解决
  • 38.752 至 41.412 这些杂峰是什么
    41.692
    41.981
    42.654
    43.670
    43.907
    45.515
    46.811
symmacros 2018/07/24
41.692 & 41.981 & 43.670& 43.907 homo Avocadofuran 46.811 2-octyl-dodecanal
附件:
  • symmacros
    第1楼2018/07/24
    41.692 &
    41.981 &
    43.670&
    43.907
    homo Avocadofuran
  • 百万个为什么
    第2楼2018/07/24
    朱老师这些是做什么用的,香料还是溶剂类呢?
    symmacros(jimzhu) 发表:41.692 &41.981 &43.670&43.907homo Avocadofuran46.811 2-octyl-dodecanal
  • zwq1973
    第3楼2018/07/24
    朱老师,这个homo Avocadofuran的cas号是多少?
    41.981 &
    43.670&
    43.907
    homo Avocadofuran
  • bigtiger
    第4楼2018/07/24
    我这里检索的是2-pentadecylfuran,cas:59958-20-2 ,这个东西是牛油果油的组分,有号称植物杀虫剂一说。不知道和朱老师的是不是一个东西。
    zwq1973(zwq1973) 发表: 朱老师,这个homo Avocadofuran的cas号是多少?
  • symmacros
    第5楼2018/07/24
    是这个CAS No. 一个东西。
    bigtiger(v3138164) 发表: 我这里检索的是2-pentadecylfuran,cas:59958-20-2 ,这个东西是牛油果油的组分,有号称植物杀虫剂一说。不知道和朱老师的是不是一个东西。
  • symmacros
    第6楼2018/07/24
    38.752 至 41.412,42.654,45.515,46.811 (2-octyl-dodecanal)都是来至Eutanol G。请参考下面的内容:
    Eutanol® G
    INCI Name: Octyldodecanol
    Company: BASF Care Creations
    Eutanol? G is a medium spreading emollient which is due to its chemical structure hydrolysis stable and therefore beneficially suitable for all formulations where a wide pH range is needed e.g. deodorant/antiperspirant and hair remover formulations. It is a clear, slightly yellow, odorless oil of low polarity with a mean molecular weight, and a spreading value of 600 mm^2/10 min. Eutanol? G has a hydroxyl value of 175-190, a refractive index (20?C) of 1.4535-1.4555, and a density (20?C) of 0.835-0.845 g/cm^3.
  • 百万个为什么
    第7楼2018/07/24
    多谢朱老师耐心解答了!
    symmacros(jimzhu) 发表: 38.752 至 41.412,42.654,45.515,46.811 (2-octyl-dodecanal)都是来至Eutanol G。请参考下面的内容:Eutanol® G INCI Name: OctyldodecanolCompany: BASF Care CreationsEutanol? G is a medium spreading emollient which is due to its chemical structure hydrolysis stable and therefore beneficially suitable for all formulations where a wide pH range is needed e.g. deodorant/antiperspirant and hair remover formulations. It is a clear, slightly yellow, odorless oil of low polarity with a mean molecular weight, and a spreading value of 600 mm^2/10 min. Eutanol? G has a hydroxyl value of 175-190, a refractive index (20?C) of 1.4535-1.4555, and a density (20?C) of 0.835-0.845 g/cm^3.
  • symmacros
    第8楼2018/07/24
    请问这个是什么样品?
  • 百万个为什么
    第9楼2018/07/26
    朱老师 这个是个香水样品
    symmacros(jimzhu) 发表:请问这个是什么样品?
  • symmacros
    第10楼2018/07/26
    香水里面会有一些非香料的成分。
