【求助】岛津GC-2014的仪器问题?
  • wangpu1979
    2007/07/18
气相色谱(GC)
  • 各位前辈,请教一个问题: GC出现这信息: COL CRG is out control是怎么回事 ,咋个处理啊?
  • 飞花刀语
    第1楼2007/07/18
    This message appears when cooling is impossible because of insufficient coolant, etc.
    If there is no coolant, turn off the system, replace the coolant, and then restart the system.
    This message may appear when cooling is impossible because the oven door is open. In
    this case, close the door and press “Reset Error.”
  • hhh.dsy
    第2楼2007/08/19
    察看该仪器的<维修手册>!
