闲鹤野云
第2楼2007/08/13
Harmonic mean reported for Half-Life, with Hodges-Lehman esdmate of median treatment difference with corresponding 90% Cl for true median treatment difference。
报告的半衰期Harmonic均值〉〉〉〉〉〉其处理差异中值的Hodges-Lehman 值,在真实处理差异中值的90%Cl
For other classes of antiretroviral agents, there is a reasonable but imperfect association of efficacy with doses that achieve Ctroush values which exceed the protein-adjusted concentration that inhibits 95% of the target enzyme (IC95) in the HIV spread assay and,
as discussed in [Sec.2.7.2.1.3], the trough concentration (C12hr) is determined to be the primary PK parameter for judging the impact of pharmacokinetic alterations on efficacy of MK-0518.
对于其他类别的抗反转录病毒因子来讲,其效果与剂量间的关系较密切但不完美。在HIV扩散检测中,其中所用的剂量所达到的Ctroush值超过能抑制95%目标酶(IC95)所需的浓度(根据蛋白质进行校准)。正如2.7.2.1.3部分所讨论的,液槽浓度(C12hr)被断定是判断药物动力学参数变化对MK-0518效果影响的主要PK参数。
nanfeiyan9999
第5楼2007/08/13
Median reported for TMAX ,with Hodges-Lehman estimate of median treatment difference with corresponding 90% Cl for true median treatment difference。
对于报告的TMAX中值,其中值处理差异的Hodges-Lehman 值,是真实中值处理差异的90%Cl????
多谢斑竹熬夜帮助,非常感激.SORRY,昨天太急没说:90%Cl意思是90%可置信区间.treatment没有治疗的意思?
您觉得这样翻译行吗?
对于报告的TMAX中值,其中值处理差异的Hodges-Lehman 值,在真实中值处理差异的90%置信区间内.
闲鹤野云
第6楼2007/08/13
闲鹤野云
第7楼2007/08/13
这里应该是治疗效果的差异中值,把我给绕晕了,想了很久不明白,现在知道了。统计太拗口。
把中值处理差异改为治疗差异中值,就差不多了,看其他斑竹和板油的建议
