第7楼2009/04/25
kinetic scattering的发生和光源并无直接的关系,昨天有个俄罗斯的朋友在rietveld_l@ill.fr邮件群中这样说到:
"If you have a perfect Si crystal then double diffraction may appear and forbidden reflections can be seen. Yesterday we discussed with my collegue his diffraction experiments with Si crystal cut along (100). He said that he clearly see forbidden (200) reflection, which appears and disappears when sample rotation is on."--Eduard E. Levin
因为在XRD中也可能存在二次衍射,这再次引起了我对二次衍射的关注。所以我想到通常XRD中看不到二次衍射的原因很可能是因为定角度比的入射和探测的衍射装置。
因此我的看法是,kinetic scattering能通过衍射装置的改善来消除。
