影子
第3楼2011/03/14
the results calculated on the dried, anhydrous, or ignited basis, provided a test for Loss on drying, or Water, or Loss on ignition, respectively, is given in the monograph
在这里,provide应该是提供的意思,干燥失重、水份或炽灼残渣的测试方法分别被提供
poorlittle
第4楼2011/03/14
似是一個免責聲明:
除非另有说明, 药典對所述之计算(方法 or 結果?)概不負責 (i.e. the user should evaluate the calculations (method, principle and/or result?) before adoption, and take his own responsibility for adopting such calculations.
Information :
http://www.nciku.cn/search/en/detail/as+is/865262
as is
1. [商业] 现况如此;概不保证;按货样
http://business.yourdictionary.com/as-is
as is
Of or relating to an offer to sell an article in its existing condition. Potential buyers are free to inspect the article but have no recourse in the event a defect is discovered after purchase.
http://en.wikipedia.org/wiki/As_is
poorlittle
第5楼2011/03/14
“provided” is a conj., it is different from “provide”
http://www.thefreedictionary.com/provided
On the condition; if
http://www.iciba.com/provided/
http://www.trgroup.com.cn/whelp/html/310.html
影子
第6楼2011/03/14
我觉得这里的as is应该与下面的意思相同:
影子
第10楼2011/03/15
以我的理解,as-is应该是“原样”的意思,参考6楼的那段话,我认为它是与dried、anhydrous、free base、ignited、solvent free对比而言的,因为药典上有些计算值(比方说含量),它是要扣除一些杂质的,包括有机、无机以及挥发性的物质等,如含量标准项下常见的是:
XX contains not less than 98.5 percent and not more than 101.5 percent of YY, calculated on the anhydrous basis.
XX contains not less than 98.0 percent and not more than 102.0 percent of YY, calculated on the anhydrous, solvent-free basis.
所以第一句我把它翻译为:除另有规定外,专论中的所有计算值采用原样计算。
也就是说没有上面那种红色文字或其它的规定,测定结果就不需要扣除那些有机无机杂质了。
