3.色谱分析:①色谱条件:电子捕获检测器;玻璃填充柱(2 m ×3 mm)内装涂有1.5%OV-17+19.5%QF-1固定液的Chromosorb W AW-DMCS担体;柱温:205℃;汽化室温度:250℃;检测室温度:270℃;载气:高纯氮流量,40 ml/min。②样品分析:将处理好的样品溶液用1μl微量注射器取0.2 μl注入色谱柱中,以保留时间定性,峰面积定量,用外标法计算残留量(10个样品带一个质控样)。
3 Mes J,Daries DJ, Turton D.Polychlori-nated biphenyl and other chlorinated hydrocarbon residues in adipose tissue of Canadians.Bull Environ Contam Toxical,1982,28:79
4 Snyder D, Reinert R.Rapid separation of polychlorinated biphenyls from DDT and its analogues on silica gel.Bull Environ Contam Toxicol,1971,6:385
