请问这句话怎么翻译?
  • 下里巴人
    2006/09/05
专业英语
  • A common solution to the equilibration problem of silica with water is to use solvent that are "half-saturated"with water .They are prepared by saturating a given volume of hydrophobic solvent with water and then mixing it 1;1 with "dry"solvent.
    提到的“half-saturated”solvent 在上面的文章中是这样说的: One trick that has been used to get around this problem is to use non-polarsolvents like hexane or methylene chloride that are half saturated with water .To accomplish this you take a volume of the solvent and saturante it with water by adding some water to it and stir it for a while,then you mix this wanter-saturated solvent and mix it with an equal volume of "dry"solvent
    请大侠赐教!
  • 该帖子已被管理者-设置为精华,下面是奖励记录:
  • 瓢虫
    第1楼2006/09/05
    解决用水平衡硅胶柱的通常做法是利用经水半饱和过的溶剂。该溶剂的制作方法是:先用水饱和疏水性溶剂,然后再与该疏水性溶剂以1:1混合。
  • 该帖子已被管理者-设置为精华,下面是奖励记录:加3积分,加3声望
  • weiz
    第2楼2006/09/05
    翻译的很好 ,不过建议最后一个“疏水性溶剂”前面加一个修饰词“无水”,与原文中的“dry”相对应。
    liang_sp 发表:解决用水平衡硅胶柱的通常做法是利用经水半饱和过的溶剂。该溶剂的制作方法是:先用水饱和疏水性溶剂,然后再与该疏水性溶剂以1:1混合。
  • 该帖子已被管理者-设置为精华,下面是奖励记录:加1积分,加1声望
  • 下里巴人
    第3楼2006/09/06
    谢谢给为老大
