m3219207
第1楼2017/06/19
Graphite furnace power supply is not operating properly.
In the Furnace page of the Diagnostics window click on the Reconnect button and allow the system to reinitialize. If the problem persists, follow the instructions below.
Shut down the application software (WinLab).
Power down the instrument's front panel switch.
Unplug the instrument from the power source for 30 seconds.
Reinitialize instrument and retry.
If error re-appears during analysis, modify temperatures and/or
cycle times to prevent overheating.
[0403]
Firmware Error Code: 424
石墨炉的电源运转不正常。
在诊断窗口的熔炉页面中,单击重新连接按钮,并允许系统重新初始化。如果问题继续存在,请遵循下面的说明。
关闭应用软件(WinLab)。
把仪器的前面板开关电源关掉。
30秒内把电源插头从电源上拔下。
重新启动仪器并重试。
如果在分析期间出现错误,修改温度和/或
循环时间以防止过热。
[0403]
固件错误代码:424
逐句翻译
