探讨光电直读光谱仪测定铝中Fe、Si、Cu、 Mg、Ga、Zn元素含量的不确定度评定
元素 (%) | Si | Fe | Cu | Mg | Ga | Zn |
U,K=2 | 0.001 | 0.0003 | 0.0001 | 0.0002 | 0.0002 | 0.0002 |
U1rel | 0.0005 | 0.0002 | 0.00005 | 0.0001 | 0.0001 | 0.0001 |
元素 | 编号 | 标准值% | 标准差%,s | 标准不确定度%,u | 相对不确定度%,urel | 相对标准不确定度%,U2rel |
Si | G211 | 0.047 | 0.001 | 0.0004 | 0.0085 | 0.0051 |
G212F | 0.114 | 0.002 | 0.0007 | 0.0061 | ||
G213 | 0.634 | 0.001 | 0.0004 | 0.0006 | ||
G214 | 0.203 | 0.003 | 0.0011 | 0.0054 | ||
G215 | 0.347 | 0.003 | 0.0011 | 0.0032 | ||
G216 | 0.537 | 0.003 | 0.0011 | 0.0020 | ||
Fe | G211 | 0.055 | 0.001 | 0.0004 | 0.0073 | 0.0046 |
G212F | 0.122 | 0.002 | 0.0007 | 0.0057 | ||
G213 | 0.773 | 0.007 | 0.0025 | 0.0032 | ||
G214 | 0.325 | 0.003 | 0.0011 | 0.0034 | ||
G215 | 0.435 | 0.005 | 0.0018 | 0.0041 | ||
G216 | 0.744 | 0.004 | 0.0014 | 0.0019 | ||
Cu | G211 | 0.0056 | 0.0001 | 0.00004 | 0.0071 | 0.055 |
G212F | 0.0003 | 0.0001 | 0.00004 | 0.133 | ||
G213 | 0.030 | 0.001 | 0.0004 | 0.0130 | ||
G214 | 0.058 | 0.001 | 0.0004 | 0.0069 | ||
G215 | 0.097 | 0.002 | 0.0007 | 0.0072 |
| G216 | 0.147 | 0.002 | 0.0007 | 0.0048 |
Mg | G211 | 0.0024 | 0.0002 | 0.00007 | 0.0292 | 0.0143 |
G212F | 0.0036 | 0.0001 | 0.00004 | 0.0111 | ||
G213 | 0.0096 | 0.0004 | 0.00001 | 0.0010 | ||
G214 | 0.067 | 0.002 | 0.0007 | 0.0104 | ||
G215 | 0.038 | 0.001 | 0.0004 | 0.0105 | ||
G216 | 0.069 | 0.001 | 0.0004 | 0.0058 | ||
Ga | G211 | 0.0042 | 0.0001 | 0.00004 | 0.0095 | 0.0105 |
G212F | 0.018 | 0.001 | 0.0004 | 0.0222 | ||
G213 | 0.026 | 0.001 | 0.0004 | 0.0015 | ||
G214 | 0.012 | 0.001 | 0.0004 | 0.0033 | ||
G215 | 0.050 | 0.001 | 0.0004 | 0.0080 | ||
G216 | 0.076 | 0.002 | 0.0007 | 0.0009 | ||
Zn | G211 | 0.0081 | 0.0002 | 0.00007 | 0.0086 | 0.0078 |
G212F | 0.0055 | 0.0001 | 0.00004 | 0.0073 | ||
G213 | 0.035 | 0.001 | 0.0004 | 0.0114 | ||
G214 | 0.126 | 0.002 | 0.0007 | 0.0056 | ||
G215 | 0.074 | 0.001 | 0.0004 | 0.0054 | ||
G216 | 0.106 | 0.002 | 0.0007 | 0.0066 |
标样 | 校正次数 | 化学成分/% | |||||
Si | Fe | Cu | Mg | Ga | Zn | ||
G211 | 未校正 | 0.0463 | 0.0545 | 0.0055 | 0.0024 | 0.0041 | 0.0078 |
校正 1次 | 0.0473 | 0.055 | 0.0057 | 0.0024 | 0.0042 | 0.0081 | |
校正 2次 | 0.0465 | 0.0543 | 0.0056 | 0.0024 | 0.0041 | 0.0079 | |
校正 3次 | 0.0465 | 0.0543 | 0.0055 | 0.0024 | 0.0042 | 0.0078 | |
校正4次 | 0.0466 | 0.0541 | 0.0055 | 0.0024 | 0.004 | 0.0079 | |
平均值 | 0.0466 | 0.0544 | 0.0056 | 0.0024 | 0.0041 | 0.0079 | |
标准偏差 | 0.0004 | 0.0003 | 0.0001 | 0 | 0.0001 | 0.0001 | |
u | 0.0002 | 0.0002 | 0.00004 | 0 | 0.00004 | 0.0001 |
urel | 0.0037 | 0.0028 | 0.0072 | 0 | 0.0091 | 0.0069 | ||||||
标样 | 校正次数 | 化学成分/% | ||||||||||
Si | Fe | Cu | Mg | Ga | Zn | |||||||
G216 | 未校正 | 0.5355 | 0.7422 | 0.1467 | 0.064 | 0.066 | 0.1168 | |||||
校正 1次 | 0.5364 | 0.7507 | 0.1472 | 0.0642 | 0.0678 | 0.1171 | ||||||
校正 2次 | 0.5369 | 0.7471 | 0.1476 | 0.065 | 0.0693 | 0.1175 | ||||||
校正 3次 | 0.5316 | 0.7433 | 0.1461 | 0.0643 | 0.0661 | 0.116 | ||||||
校正 4次 | 0.5377 | 0.7561 | 0.1485 | 0.0637 | 0.0657 | 0.118 | ||||||
平均值 | 0.5356 | 0.7479 | 0.1472 | 0.0642 | 0.0670 | 0.1171 | ||||||
标准偏差 | 0.0024 | 0.0057 | 0.0009 | 0.0005 | 0.0015 | 0.0008 | ||||||
u | 0.0011 | 0.0025 | 0.00041 | 0.0002 | 0.00069 | 0.0003 | ||||||
urel | 0.0020 | 0.0034 | 0.0028 | 0.0034 | 0.0103 | 0.0029 | ||||||
U3rel | 0.0030 | 0.0031 | 0.0055 | 0.0024 | 0.0097 | 0.0053 |
车面次数 | 激发次数 | 化学成分/% | |||||
第1次 | 1 | 0.037 | 0.079 | 0.0002 | 0.0010 | 0.0139 | 0.007 |
2 | 0.0368 | 0.0778 | 0.0002 | 0.0010 | 0.0139 | 0.0069 | |
3 | 0.0367 | 0.0771 | 0.0002 | 0.0010 | 0.014 | 0.007 | |
4 | 0.0375 | 0.0804 | 0.0002 | 0.0010 | 0.0141 | 0.0072 | |
5 | 0.0374 | 0.0794 | 0.0002 | 0.0010 | 0.0141 | 0.0071 | |
6 | 0.0368 | 0.077 | 0.0002 | 0.0010 | 0.0141 | 0.007 | |
7 | 0.0376 | 0.0792 | 0.0002 | 0.0010 | 0.0141 | 0.0071 | |
8 | 0.0379 | 0.0799 | 0.0002 | 0.0010 | 0.0143 | 0.0072 | |
第2次 | 1 | 0.0376 | 0.0811 | 0.0002 | 0.0010 | 0.0143 | 0.0072 |
2 | 0.0376 | 0.08 | 0.0002 | 0.0010 | 0.0144 | 0.0073 | |
3 | 0.0375 | 0.0796 | 0.0002 | 0.0010 | 0.0143 | 0.0072 | |
4 | 0.0375 | 0.0805 | 0.0002 | 0.0010 | 0.0143 | 0.007 | |
5 | 0.0375 | 0.0787 | 0.0002 | 0.0010 | 0.0144 | 0.0073 | |
6 | 0.0373 | 0.0789 | 0.0002 | 0.0010 | 0.0143 | 0.0072 | |
7 | 0.0377 | 0.0802 | 0.0002 | 0.0010 | 0.0143 | 0.0072 | |
8 | 0.0374 | 0.0798 | 0.0002 | 0.0010 | 0.0143 | 0.0072 | |
平均值 | 0.0374 | 0.0793 | 0.0002 | 0.0010 | 0.0142 | 0.0071 | |
标准差 | 0.0004 | 0.0012 | 0 | 0 | 0.0002 | 0.0001 | |
u | 0.0001 | 0.0003 | 0 | 0 | 0.00004 | 0.00003 | |
U4rel | 0.0024 | 0.0037 | 0 | 0 | 0.0029 | 0.0042 |
测定元素含量/% | 相对标准偏差 RD,/% | 相对标准不确定度 U5rel |
≤0.001 | 14 | 0.081 |
>0.001~0.01 | 9 | 0.052 |
>0.01~0.10 | 6 | 0.035 |
>0.10~0.50 | 5 | 0.029 |
>0.50~1.0 | 2.5 | 0.014 |
>1.0~8.0 | 2 | 0.012 |
>8.0 | 1.5 | 0.009 |
元素 | Si | Fe | Cu | Mg | Ga | Zn |
Ucrel | 0.0356 | 0.0356 | 0.0981 | 0.0823 | 0.0379 | 0.0530 |
Uc(%) | 0.0014 | 0.0028 | 0.00002 | 0.00008 | 0.0005 | 0.0004 |
U(%) | 0.003 | 0.006 | 0.00004 | 0.00016 | 0.0010 | 0.0008 |
C(%) | 0.04± 0.003 | 0.08± 0.006 | 0.0002± 0.00004 | 0.0010± 0.00016 | 0.014± 0.0010 | 0.0071± 0.0008 |
