happyjyl
第1楼2007/02/27
此为递交于1987年9月16日,申请序列号为097194申请的部分继续申请,现已作废。
continuation-in-part: Generally referred to as a 'C.I.P' this is essentially the same as the continuation with the exception that some new material may be included. The disclosure of the parent is usually amplified and the C.I.P may claim the same or a different invention. A C.I.P application is accorded the benefit of the filing date of the parent application to the extent of the two applications' common subject matter. The C.I.P must be filed while the original parent application is pending for any disclosed material in common with the parent.
file an application:提出申请
