我在故我思
第1楼2009/09/01
Effects on health
As a precaution, manufacturers advise that DEET products should not be used under clothing or on damaged skin, and that preparations be washed off after they are no longer needed or between applications.[11] DEET can act as an irritant;[4] in rare cases, it may cause skin reactions.[11]
In the DEET Reregistration Eligibility Decision (RED), the United States Environmental Protection Agency (EPA) reported 14 to 46 cases of potential DEET-associated seizures, including 4 deaths. The EPA states: "... it does appear that some cases are likely related to DEET toxicity," but observed that with 30% of the US population using DEET, the likely seizure rate is only about one per 100 million users.[12]
The Pesticide Information Project of Cooperative Extension Offices of Cornell University states that "Everglades National Park employees having extensive DEET exposure were more likely to have insomnia, mood disturbances and impaired cognitive function than were lesser exposed co-workers". [13]
When used as directed, products containing between 10% to 30% DEET have been found by The American Academy of Pediatrics to be safe to use on children as well as adults but recommends that DEET not be used on infants less than two months old.[11]
Recently, DEET has been found to inhibit the activity of a central nervous system enzyme, acetylcholinesterase, in both insects and mammals.[14] This enzyme is involved in the hydrolysis of the neurotransmitter acetylcholine, thus playing a role in the function of the neurons which control muscles. Because of this property, many insecticides are used to block acetylcholinesterase, which leads to an excessive accumulation of acetylcholine at the synaptic cleft, causing neuromuscular paralysis and death by asphyxiation.[15] DEET is commonly used in combination with insecticides and has the capacity to strengthen the toxicity of carbamates, a class of insecticides known to block acetylcholinesterase. These findings bring evidence that, besides having known toxic effects on the olfactory system, DEET also acts on the brain of both insects and mammals, and that its toxicity is strengthened in combination with other insecticides.
这是在维基百科中检索到的
